I'd like a feature where I can set two shutter speeds, to allow the camera to alternate between the two speeds on each frame. Put closely together, the exposure variations could be (in post) merged into single frames with high dynamic range. It obviously would not be perfect, due to scene variations with objects moving quickly, but for most situations involving slow or still scenes it would be close enough to satisfactory (or would at least provide interesting FX). Even better, if the two shutter frames could follow one another back to back as closely as possible, treating the frames as grouped pairs. If this works really well for two frames, the concept could be expanded to three (or more) frame groupings for even greater dynamics. But, two frames is good enough for now.
Frame Number : Shutter Speed
Frame #1: 1/100
Frame #2: 1/500
<Wait>
Frame #3: 1/100
Frame #4: 1/500
<Wait>
Frame #5: 1/100
Frame #6: 1/500
<Wait>
Frame #7: 1/100
Frame #8: 1/500
<Wait>
ETC...
It would also allow a choice, in post, between two exposure levels for a given scene. So you could expose for windows on one speed, expose for the interior lights on the other speed. Then in post you could say "I think this will work better using the window exposure", then you'd just pull out the even or odd frames to accommodate. Shooting at 48fps would give 24fps on each shutter speed.
Frame #1: 1/100
Frame #2: 1/500
<Wait>
Frame #3: 1/100
Frame #4: 1/500
<Wait>
Frame #5: 1/100
Frame #6: 1/500
<Wait>
Frame #7: 1/100
Frame #8: 1/500
<Wait>
ETC...
