mrsteinberg
- Sep 12, 2007
Just got a workflow working.
Edit in FCP XML out - import XML to Crimson XML to Redcine import alias rd3 files from crimson and then import the Crimson XML- Grade-Resize and render out in redcine - Import files to Crimson and make a new XML to *FCP xml to - Color - grade render and then xml back to FCP for Final Online.
I used*1920x1080 25P 10 bit uncompressed quicktime out of redcine and color.
I also tried DPX in color. Redcine got some frames looping in the end of one clip but you got so much to pull with the colors and DPX files so I wish this would work.
My other thing is that I still only can edit the smallest proxies in fcp without a crash that is real enoying. If the medium size would work with out re rendering everything to Pro Res I would say I have a working workflow that I am satisfied with. Even thou it's a huge hassle with all the xml's and having to go via Crimson, redcine should be able to import FCP xml straight away.
Any one that can help me out there and I hope all this text made sense.
Best Martin Steinberg
www.steinbergfilms.se
Latest work: http://steinbergfilms.se/videos/wrdc-find-al-gharbia-web-hq.mov
