Trevor Meier
I've done some ramping tests, with a GPIO trigger and On-Record, and have run into a rather nasty bug.
Tests from 24-48 fps work fine. But go any higher (60, 120, etc.) and things start getting weird on playback. The ramp occurs as it should, either starting from record or from when the trigger is hit and landing at the target frame rate. But then, after a few seconds the clip starts speeding up, dropping down to what looks like around 12fps.
Again, this is only on speed ramps above 48 frames (23.98 timebase).
Any ideas?
Any ideas?
