Dory Breaux
- Feb 9, 2008
- Age
- 35
Hey all, I was wondering if you could help me figure out what the minimum setup for a RED One would be. So far I've come up with:
RED Body (I'd assume thats a given
Base Production Pack
5inch LCD/cable
Power Pack
4x CF Cards (to start with, mostly cause I do alot of work where weight is a concern)
Nikon Mount
Two extra rods
NIKKOR 18-200mm f/3.5-5.6G IF-ED (and probably another, wider and faster piece of glass)
RedRock Mattebox (or something of the same functionality/price range)
other obvious stuff such as a tripod and whatnot.
I cut all my stuff with Avid and have NO want to switch to Mac/FCP, so workflow might be a tad tricky but it seems that lots of people are figuring it out, and if RED ever releases the SDK, things should get easier...
the way I calculate it, everything should come out to around 25-30k. Is their anything I left out? I'm talkin bare bones here, for starters. I Probably wont use 4K much when I cant dump from the CF cards, mostly cause the stuff I'd shoot when i dont have a dump/storrage device avalible need the FPS of 2k/3k.
Let me know your thoughts!
Later,
Dory
5inch LCD/cable
Power Pack
Nikon Mount
Two extra rods
Later,
Dory
