Steve Sherrick
I've experimented with capturing the 1080P output of Red Build 16 into FCP via a Kona 3 and have not had any luck. The signal comes in with a greenish/purple solarized effect. Checked it with a direct connection to an HD-SDI monitor as well with same results.
Anyone else try this? Same experience?
Also, it would be cool if the audio would travel down the HD-SDI pipe as well. That would offer a pretty cool realtime processing system (even though you have to compromise on the quality a bit). Some jobs it would be perfect for.
