tj williams
I’m interested in starting a discussion of getting sets of primes together out of still lenses issues such as matching wide iris which are below 2.0 and capable of being controlled by the proposed Birger Engineering Focus/Iris system.
Other issues I haven't seen discussed include:
Color matching among the Nikon/canon lenses in a set of primes
Comparisons of new AF Zooms to AF prime lenses in terms of sharpness, since clearly these focal ranges can easily be covered by two Nikkor Zooms.
NIKON LENS PRIME SET: Purchase
16mm Nikkor 2.8 Autofocus……600*
20mm Nikkor 2.8 Autofocus……410
24mm NIkkor 2.0 Manual………800*
28mm Nikkor 2.8 Autofocus……210
35mm Nikkor 1.4 Manual……....700*
50mm Nikkor 1.4 Autofocus……250*
85mm Nikkor 1.4 autofocus…….925*
105mmNikkor2.0 autofocus…….925
ZEISS SPEED PRIMES rental
18mm Zeiss T1.3………..70
25mm Zeiss T1.3………..70
35mm Zeiss T1.3……….70
50mm Zeiss T1.3………..70
85mm Zeiss T1.3………...70
65mm Zeiss T1.3………...70 (often not included in std. set)
Here is a standard set of Zeiss prime High speed lenses. Rental of set $375+ per day.
Above is a set of similar Nikkor lenses. Estimated new purchase price $3200+
After reading the thread about the Birger engineering company that wants to develop a focus system for Nikon/.Canon primes I started assembly of a list of those auto lenses which may prove most desirable in Nikon.
One big problem I noticed right away was that it is hard to get a set similar to Zeiss where all the lenses are fast below 35mm I couldn’t find a 1.4 Nikon on Ebay or B&H
Also I noticed that several of the lengths I’d use are not available as Auto Focus. For instance there is no 25mm Nikon so I’d have to use a 28 rather than the slightly wider 24mm which is only available in manual. Also I couldn’t find an AF 35mm. So these lenses couldn’t be controlled by the proposed focus system.
This focus system is an exciting development since it will allow Canon Auto lenses to be iris controlled with a remote and also spread the focus/iris of both Canon and Nikon AF lenses over a sizeable remote dial to allow exact focusing irising of these still lenses.
Probably this has some errors.
Corrections are welcome.
