- Admin
- #1
Thanks Deanan!
There has been some nice ALE work in this release to get all the metadata into the post workflow. This does remove MetaCheater from the process, but for the better as both time of day and edgecode are tracked all through post and exported as needed as well as long and short file names so EDL's can be 4 or 16 as needed.
The whitepaper on the process will be available in a couple weeks. But in the meantime, I made a video that is now on YouTube that shows the basic steps.
http://www.youtube.com/watch?v=Q7m26ay6AB8
Since this was an early version, the UI may not look the same, as it is missing the audio work done by Deanan. If the source files have audio, be sure to check the audio compatibility box.
I have attached the Automator that I made that accesses the actions.
Michael
The RSX updating for in/out is now better. It'll be in the next version.
REDline multithreading performance doesn't seem to be great. We're seeing much better performance running four instances set to use two threads each vs. one instance set to use 8 threads.
