Greetings all,
It's my first post here so hello everyone and thanks for the wealth of advice in the past posts I've been trawling. I work at a small post production house. In the edit department we're set up exclusively with PowerPC Macs that double as cheaper online suites. There is also a Flame for finishing, and 3D use Windows XP machines. We typically only work in SD but the Macs can comfortably handle HD if required so there's no need for us to upgrade to Intel Macs. Or so I thought..
Today I'm trying to get my head around the Red workflow as we have a TVC job coming in over the next few weeks. The process is a little more complicated that I originally assumed, having based my expectations on a previous Panasonic P2 job we did.
From my limited understanding I will need to :
- Load raw Red clips in RedCine on one of the Windows machines
- Export everything at a lower resolution with timecode for offlining
- Edit as normal on FCP
- Bit hazy as to how to proceed from here
So I'll just fire away with the questions that have had me scratching my head:
1) How do I batch export from RedCine? I'll need to transfer absolutely everything for the offline at SD res.
2) Is there a distributed render option for exporting via a render farm?
3) After the offline is approved, how do I re-export JUST the portions of takes I've used in my edit based on an EDL, remembering that I ONLY have access to Windows PC's and PowerPC Macs. I'll probably finish at 1080p using Blackmagic 10bit, so I really want to avoid exporting unnecessary data (20 seconds at this codec is 3 GB, so 90 minutes of raw shoot is around 800 GB).
4) Everytime I export DV-PAL quicktimes from RedCine, RedCine crashes. Anyone else experience this problem or know of any workarounds? Anyone recommend any other suitable codecs for offlining available on a PC?
5) And while I think of it, is it worth investing in R3DData to verify the shot footage on set? Are there many issues with the Red camera shooting/writing blanks?
Thanks for reading,
Paul
Thanks for reading,
Paul
