Hi All,
Could you advise on the following..
If the end product only needs to be 2K. Then does the following work.
1. Use your 35mm glass (say Red 18-50).
2. Shoot 4K when you want the wider end of the lens(18-50)
3. Switch to 2k and in effect double the lens to a 36-100.
If this works then it is similar to using a doubler on a video lens. If it does work then..
4. How long does it take to switch between 4 and 2K.
5. Can you switch without any problems in regard to the storage you are recording onto.
6. Would the quality be better if you used S16mm glass in 2K as apposed to cropped 35mm glass
7. Or would it be simpler to shoot 35mm 4K and then just crop in to increase the lens size.
Thanks in advance.
Fred
Thanks in advance.
Fred
