Features by build
Stuart English
Red Team
Irvine, Ca
Another fun one: a breakdown of functions added by firmware build since the very first update - Build 4, Sept 7th, 2007
Build 4
* Frame Guides have been updated to better outline the recorded area,
* 16:9, 14:9 and 4:3 ACTION and TITLE CURSORS are correctly aligned
* Slower fan speed on record is now operational.
* Rear status display properly reports the true status of the digital media.
* Prevent multiple Project Frame Rates on a single piece of digital media.
Build 5
* Addressed reported record errors to CF card digital media.
* Increased brightness and contrast of RED-LCD for improved visibility
Build 6
* Addresses reported failure to slow fan speed during record.
* Additional frame guides: USER C (2.40 safe), USER D (anamorphic)
Build 7
* Alpha test – not released
Build 8
* Support for RED-EVF display
* Tri-Level Sync Genlock (shutter lock)
* ASA based exposure control
* Improved accuracy of Auto White Balance calculation
* Additional shutter speeds at 1/25, 1/30, 1/400, 1/800, 1/1200
* 2K at Project Frame Rates of 23.98, 24.00, 25.00, 29.97, 30.00 fps
* Variable Frame Rate recording at 1 – 25 fps 4K, 4K 2:1, 1 – 75 fps 2K
* Improved Accuracy of Time Code in Jam Sync (external reference) mode
* On-camera QuickTime movie creation for 4K, 4K 2:1 and 2K
* Selection of Edge Code or Time Code as primary time display.
* Waveform based exposure display (preliminary version)
* Histogram based exposure display (preliminary version)
* Waveform based focus assist (preliminary version)
* Additional Frame Guides – USER C and D
* Reporting of Build, Version and P.I.N at conclusion of boot up
Build 9
* Playback of recorded clips on camera.
* Addition of Simple Exposure Meter – indicates clipping in R G B channels
* Enhanced Focus Assist Algorithm with adjustable sample window
* Improved Accuracy of Time Code when not in Jam Sync
* Camera log file created on media unmount
* PIN, Build and Version data reported on request in status display
Build 10
* RED-EVF plus Preview HD-SDI / HDMI output simultaneously active.
* Addition of Video or Video + GUI monitoring modes on RED-LCD.
* Addition of 2K 2:1 recording mode.
* Addition of 50.00 and 59.94 Project Frame Rates for 2K and 2K 2:1
* Addition of 50 fps / 60 fps selection for HD-SDI outputs
* Addition of GPI trigger enabled TIMELAPSE (one shot) recording.
* Addition of GPI trigger enabled RECORD and GPO external tally output
* Addition of RGB COMPOSITE or LUMINANCE Histogram
* Addition of RGB Channel Exposure Meter
* Addition of SPOT EXPOSURE meter
* Addition of DARK DETAIL mode for RED-EVF
* Addition of SYNCED or FIXED refresh rates for RED-EVF
* Addition of enable checkbox for USER 1 and USER 2 keys in KEYMAP
Build 11
* Addition of 29.97 fps Project Frame Rate for 4K 2:1 record resolution.
* Increased Varispeed range to 1 – 30 fps for 4K 2:1 record resolution.
* Addition of GPO tally at completion of STEP RECORD enabled in TIMELAPSE
Build 12
* Audio recording and metering
* Audio playback via QuickTime Reference Files and QuickTime Player / FCP.
* Addition of OPEN GATE mode for Viewfinder and other Monitor outputs
* Addition of False Color and Zebras to HDMI and PVW HD-SDI outputs.
* Interval based TimeLapse.
* Frame rate ramping mode.
* Added GPIO programmability.
* Addition of SET TIME (Hours / Minutes / Seconds) in SETUP menus.
* Addition of TimeZone Offset to (GMT) time and day settings.
* Media directory now formatted as Camera Letter + Reel Number + Date.
* Addition of BACK SHADING (black level calibration) in MAINTENANCE
* Timecode displayed by QuickTime Player with QuickTime Reference movies created by camera at 50.00 and 59.97 fps corrected.
Build 13
* Resolution of audio hiss on boot up.
Build 14
Build 15
* Addition of RECODE 36 Compression Quality Setting.
* Addition of 3K and 3K 2:1 record modes.
* On-camera audio playback (headphone, mini-XLR and HDMI)
* Increased frame rate (100+fps) for 2K recording modes.
* 2:1 lens Anamorphic (ANA) recording modes for 2K, 3K, 4K
* Support for simultaneous RED-EVF, RED-LCD and HD-SDI/HDMI outputs.
* Addition of Relative Shutter Speed control
* Shutter speed reporting in Degrees or 1/xx Sec format.
* Enhancement of Frame Rate Ramping control.
* Enhancement of Histograms to logarithmic based display.
* False Color Focus indicator (red edge highlight over monochrome)
* Camera LOOK file export/import to SD Card.
* Addition of root directory (.RDM) to digital media.
* Addition of full size _F QuickTime Reference Movie
* Adjusted QuickTime file so audio displays as discreet channels
* Improved RED-DRIVE data synchronization
* Resolution of D.C offset in audio recordings
* Clip Name and starting Timecode in status display on playback.
* Use meter reports in hours rather than minutes.
Build 16
* New .R3D file format - compatible with new QuickTime Codec, RED ALERT.
* Digital Signal Processing optimization.
* Image Compression Optimization.
* Preliminary support for RED 16GB CF cards
* Support for 4K 16:9 recordings in REDALERT and QuickTime applications.
* Fixed high detail scene codec errors in 4K 16:9 recordings.
* Improved audio sample to video frame synchronization (lip sync)
* Addition of REDspace and RAW viewing modes.
* Updated file name structure to eliminate duplicate file names.
* Addition of Pre-Record (10 sec or 30 sec loop) mode.
* In-camera 1080p playback of REDCODE RAW 4K / 3K / 2K .R3D files.
* Addition of Time Code output on LEMO 5 pin timecode connector
* Addition of MONO mode Histogram.
* Seperation of Sensitivity (ASA) and Exposure (Compensation) parameters.
* Addition of Burst record mode in Timelapse menu.
* Added RED-EVF control over Audio, Shutter, ISO and Varispeed
* Added programmable Tonal Response Curves menu.
* Addition of Grey Scale to look around area of GUI.
* Added ability to see video during boot up sequence.
* Look Around on HD PREVIEW outputs when LCD and EVF are both active.
* Added 1.85 and 2.40 Safe Action and Safe Title Protection Guides.
* User programmability of A, B, C keys and USER 1, 2, 3, 4, 5 keys
* Return to last menu position, when UNDO-SYSTEM is pressed
* Disabled auto-reset of reel counter on change of project time base.
* Added RESET # (manual reset of reel counter) in MEDIA menu.
Build 17
* RAW exposure meter.
* 4K HD recording mode (3840 x 2160 pixels).
* Support for RED 16GB CF cards and RED-RAM 64GB flash drive.
* Embedded time code in HD-SDI outputs.
* Embedded audio in HD-SDI outputs.
* CROSS JAM and CROSS GEN timecode functions
* Improved JAM SYNC operation: removed requirement to record before syncing.
* Genlock (Tri-Level Sync) available when operating with OPEN GATE.
* Added GPI trigger functions - Pre-Record, Shut Down, Play Clip, Next Clip.
* Added ability to disable GUI elements - EVF menus and Grey Scale defaulted OFF.
* Added ability to defeat EVF menu controls when EVF menu display is set to OFF.
* Added warning screen to advise if media is removed without first Unmounting.
* Non-speed verified CF cards now permitted to record at 2K RAW resolution.
* Resolved RED-LCD sometimes tearing in lower 10% of screen with 4K footage.
* Re-sized system error messages from full screen to upper central area of GUI.
* Added flashing "RECORD dot" within GUI to indicate system error.
* Resolved 29.97 fps Time Base QuickTime reference file issue with long record times.
* S4/i Lens Data Interface (requires corresponding Lens Interface hardware).
* Allow lens Distance data reporting in Feet or Meters.
* Revised audio PPM metering (requires corresponding Revision 2 audio board).
* Addition of Audio LINE input gain control 0dB / 10 dB.
* FALSE COLOR exposure meter tracks VIEW selection - REC709 / REDspace.
* Added user programmable Safe Action / Title guides.
* Changed MAGNIFY to display 1:1 native sensor resolution.
* Added selection to playback clips using CLIP or CAMERA LOOK values.
* Added USER PREFERENCE file.
Build 18 (Beta test - not released)
* Native 1.2:1 anamorphic recording modes (4K / 3K / 2K)
* Added 1.2:1 anamorphic frame guides / monitor de-squeeze.
Build 19
Build 20
* Enhanced Color Matrix.
* Decreased noise in blue channel, especially under tungsten lighting.
* Increased accuracy of skin tones on RED-EVF, RED-LCD, and HD-SDI monitor outputs.
* Fixed ""audio codec error" with audio enabled clip playback from RED-DRIVE.
* Fixed "green flash" with audio enabled clip playback from RED-DRIVE.
* Fixed random camera reboot on clip playback from RED-DRIVE.
* Fixed random camera reboot on communications error from S4/i lens data port.
* Corrected Look Around on HD-SDI/HDMI output for 4K / 3K / 2K ANA modes.
* Changed USER KEY 4 to VIEW RAW and USER KEY 5 to COLOR.
* Adjusted Sensor RAW meter highlight clip indication response.
* Corrected FALSE COLOR error in VIEW RAW mode
* Simplified FALSE COLOR overlay for RAW, REC709 and REDspace.
* Eliminated camera "stall" during boot up sequence.
* Eliminated requirement to wait 10 seconds between power down / power up.
* Eliminated "blue screen" LCD / EVF symptom following camera re-boot.
* Eliminated "menu lock up" when connected to consumer HDTV set via HDMI.
* Modified PPM scaling and added 0dBu / -20dBFS Reference Level Mark.
* 48V Phantom Power maintained over power cycle (Rev B audio boards only).
* Added OUTPUT LEVEL to SOUND menu to adjust audio LINE output level.
Build 21
* 4.5K WS (Widescreen) resolution,
* REDCODE 42 for 4.5K WS, 4K 2:1, 4K ANA, 4K HD,
* VIEW mode indicator,
* Video Genlock for HD-SDI PVW output,
* Support for s4/i data from Cooke Prime and Zoom Lenses,
* Enhanced USER PROFILE function,
* Project CONFIGURATION function,
* Camera STATUS overview,
* REPEAT FRAME and IN-RECORD flags in HD-SDI PVW output,
* CLIP NAME metadata in HD-SDI PVW output,
* Increased precision of shutter PHASE control.
* Adjustable LOOK AROUND opacity.
Copyright (c) 2009 RED Digital Cinema, All Rights Reserved.
Impressive list... Great stuff, thanks Stuart! Makes you wonder what else you guys have planned for the future. Really amazing what you have accomplished in so little time...
So what build did the cameras have installed when they first started shipping?
all that in the time it takes to concieve and birth a child!
Technical evolution at its best - real pioneer work.
I vote sticky and constant update with new releases!!:construction:
Keep it comin' Stuart. Amazing to see the progress!
Very, very impressive list.
It is time to start Build 17 list.
Let me start here:
* enable /i metadata interface
* switch off EVF menus option
* fix phantom power (first in software by adding inverted raw hiss before writing it to QT proxy)
* add RED super grip support
* standby mode
* 1:1 zoom
* shutter speed bracketing for HDR moving pictures
* audio on HD-SDI
Build 17
Build 17
Very, very impressive list. It is time to start Build 17 list.
Let me start here:
* standby mode
* 1:1 zoom
* audio on HD-SDI
Well lets compare - :construction: we added
* fix phantom power - via new audio board
* 1:1 zoom
* audio (and timecode) in HD-SDI
Would be cool to have also a list of Features intended to bring on future builds 19, 20 :)
curious when 4.5k comes
can you please explain what does S4i support mean? Because I got S4's and build 21, but see no data on the screen.
I don't think it is enabled by default. You have to go into the camera preferences to turn it on.
System > Setup > Remote -- S4i Lens
System > Setup > Preferences > Display -- Lens Data
I've enabled these menu items, but no luck. Do not see any information on screen.
