Dan Hudgins
- Feb 16, 2007
- San Francisco, CA USA
- www.dancad3d.com
It should be possable to get a longer scale for daylight or high contrast lighting by using two RED ONE (tm) cameras and a 10%-90% beam splitter in front of the cameras lenses.
The cameras would need matched lenses, and the camera rig would need to be solid and have adjustment to compensate for the 1/3 thickness of the beam splitter so the nodal point of both lenses correspond.
The dimmer camera could be cut more with ND to get a spread of 5 to 8 stops between the cameras. You would not want an 11 stop spread since you need to curve over the high (and low) clip point before the two images are FUSED.
Both frame sets would need to be preped with curves to avoid any sharp clipping before being fused, and the output set would be run through curves and color matrix to get a more film like rounded curve.
Both cameras would need to be in sync.
Since many RED ONE (tm) owners already have two cameras, a two camera rig could be sold as an accessory with a 10%-90% beam splitter used for extended range shooting, and a 50%-50% beam splitter used for 3D stereo shooting.
The images would need to be cropped a little and resized to make up for registration errors. The iris should be the same in both cameras unless you want a sharp+soft image for effect.
To extend this idea, with three cameras and two beam splitters you could shoot through RGB filters, and with 9 cameras you could shoot extended range with RGB filters, although you could need long lenses and a field lens with the prime lens in front, not with a ground glass, just relay optics in order to get wide angle shots.
