Post your requests for Apple Final Cut/Studio/Colour etc here
A simple cloning brush or tool in either FCP or Color. This is one thing that was indispensable for me in Avid and the fact that there isn't even a descent plug-in that can do this well for FCP surprises me. I've tested the CHV and other clone plug-ins but they are all clunky and don't work well. A simple elegant, photoshop-like clone brush would be wonderful for scratch and dust removal and the ability to remove unwanted items within a frame. There are other ways to deal with these issues, but the are much more laborious and time consuming. CLONE TOOL PLEASE!!!!!
Full 10bit support
full 4k support
integrated dpx/cineon workflow
Stable Gamma
Blu Ray Authoring in DVD Studio
I like color to be seperated from FCP, just a bit easier exchange especially still frames, or support of alpha channels.
Full 10bit support
full 4k support
Stable Gamma
Votes +1!
also agree on simple cloning tool ala AVID
25 fps dpxs working properly in color
Gammashift issues solved, not only for prores
RAW playback/editing in both FCP and Color, and not "as prores files"
Distributed rendering in color (and please in FCP, too...)
10bit rgb throughout
Gamma fixed above all.
Then R3D support at least in Color and better colorspace in FCP.
Emmanuel
I should preface with a disclaimer that my opinions on Color are based on my experience in the workflow of a fast-turnaround, high-client expectation commercial post-house. YMMV for other workflows such as short films, longformat docs, etc...
Roundtripping between FCP and Color.
Roundtripping used to totally suck in FinalTouch/Color, but as someone who uses Color on a near-daily basis in client-supervised sessions (and has spent many many many hours learning to troubleshoot its quirks) I find 95% of roundtripping scenarios in Color 1.0.2 to be working problem free, at this point.
Of course things like graphic inserts, FCP generated freezeframes, time-remapping (although Constant speedchanges and reversals generally work fine now), nested sequences etc are still problematic, but are not showstoppers, given the major improvements in other areas of Color that *were* showstoppers in 1.0 and 1.0.1 (i.e. color/gamma shifts in renders, unwanted deinterlacing when Geometry Room is used, rendering of speed changes etc .)
Proper UI for color.
I don't understand what you mean by a "Proper UI". This implies that the UI is "improper", which it is anything but. The Color UI is generally fine. It could stand to inherit the standard Mac OS X file requestor dialogs, but I definitely dont see any need in Aqua-fying the overall interface. I can absolutely fly in the Color interface, even without a control surface.
Basically, make Color an integrated part of FCS, not some last-minute-add-on.
The WORST thing that can happen to Color is to integrate it into the FCP interface. Low-level integration, in terms of seamless, native translation/conform of FCP projectfiles would be a level of "integration" that would be super awesome, but the reason why Color excels at what it does is precisely because it's not shackled by the terrible UI conventions of FCP.
As an aside, I think threads like this are useful in terms of publicizing feature requests and bugs that other users may not be aware of, but please know that NOTHING you post on a thread like this will make any difference in terms of whether Apple improves on the product or not.
By internal Apple policy, software engineers are not allowed to address bugs or feature requests that are not formally submitted through the Apple Bugreporter (http://bugreport.apple.com). Basically, if it isn't in thier bug tracker (to which feature requests can also be submitted), it officially doesn't exist. It sucks, but that's how Apple works.
So instead, I would suggest that people spend thier time and energy submitting bugs and featurequests to bugreport.apple.com (you can sign up for a free ADC account in order to do so), instead of--or in addition to--posting them on forums like this. Posting gripes on message-boards makes you feel better by getting it off your chest, but submitting your gripes directly to Apple will actually get shit done.
Very good points, Mel.
For me Color right now is a stand-alone application, and not really part of the FCS suite, it just "feels" totally different. But that comes down to personal preference and not having the time to get used to a totally new UI. I don't really see why Color could not be like the 3-wheel color filter in FCP?
And yes, I have in the past submitted feature requests to Apple, and two of them even made it into subsequent releases. If you either have a Killer Function idea or if enough people make a request, then Apple does indeed listen. Just don't expect feedback ;)
Visual Awesomeologist
That must be the coolest job title I've heard since the web bubble burst ;) And in Honolulu on top of it all! :)
I would like them to fix the three color histogram bug. In the three color histogram there are red, green, and blue histograms but the blue histogram is really just the red histogram again.
The curves need to be keyframable.
Color needs to support USB control surfaces like the Tangent Wave when it becomes available.
I want Stand Alone Apple Color, that can batch capture and print to tape directly via AJA, Decklink and Bluefish 444 cards.
