Any suggestions for my workflow on PC. Appreciated
Kim
Hi all,
I am PC user, so I'm really confuse with R3d seems towards Mac. RedAlert is only for Mac. I intend to borrow my friend's Macbook to generate QTime files from R3D by RedAlert. Finish this step, i bring all QTime files to Avid PC via ALE. All i need is EDL (for any house with Assimilate SCRATCH systems) or XML for RedCine (hope v3 release soon). Is this workflow available? is EDL or XML correct for online?
Anyones. Thanks in advanced
Kim
EDL for composition. The XML export is a pull list as XML expected by RedCine to regenerate the spans of R3D files needed for the final conform. Although there will be an XML of the seqeunce as well, RedCine will not take that in.
Michael
It sounds like there is no way to take even low quality renders out of Redcine into Avid, edit them and then XML back into RedCine with an export back to Avid. Is that correct or is there some way to do it on a PC? I ask because I know I have one client that edits PC Avid and wants to use the RED but can't find a decent workflow.
Matthew
RedCiine rendered out as DNxHD 115 (it defaults to this and there is no way to change it)
Use MetaCheater to create ALE file
Import ALE and merger QT reners.
This will give you the metadata needed to generate an EDL. Scratch and other DI systems can take that EDL in for conform. In your mail you mentioned going back to Avid once again - what is that for? Are you looking to finish on Avid as HD?
Michael
Seeing as RedCine can only create DNxHD 115, you are stuck in a position to determine whether that is good enough for finish or not. Certaibly there have been plenty of shows finishing at that data rate, that is a decision you have to make. Then the process is really to "one light" in RedCine then edit and finish off the imported files.
Michael
Michael
After offline editing, there's always a possibility to rerender the used clips to non Avid codecs in RedCine and importing them uncompressed (or a codec > DNxHD 115) into Avid for finishing. Make sure you use the same filename for easy batch import.
The downside is that you need a lot of harddrive space for both the rendered Quicktimes and the Avid media. But for spots and shortform it's very doable.
