Graeme Nattress
RED Problem Solver
10bit DPX is fine. Just don't use linear light with it. Use Redlog or REC709 gamma, or one of the PDLog options.
Graeme
Graeme
Thanks CWS, the problem is not with the importing of the dpx log files out of Redcine into Color, but that Color seems to assume that any DPX log files it imports are 95-685 range, I can't find where in Color you can change the settings for the log files black and white points and gamma etc the way you can adjust the loglin input settings in Shake for example. Any suggestions appreciated.
www.belladonnathemovie.com
- Printing Density: This pop-up menu is only selectable when the current project is set to use Cineon or DPX image sequences. It lets you explicitly choose the numeric range of values that are used to process color to ensure compatibility with your post- production pipeline. These options determine what the black and white points are set to in media that’s rendered out of Color. There are three options:
- Film (95 Black – 685 White : Logarithmic)
- Video (65 Black – 940 White : Linear)
- Linear (0 Black – 1023 White)
I agree with that.Which would suggest PDlog685 is the best curve for Color.
