Mike Prevette
I Love the Red On-board. It's amazingly light and thin, adequately bright, and sooo sharp. BUT it also terrifies me by being so svelt. I am still waiting on my EVF so it's my only onboard viewing system unless I want to rent another onboard or someone else EVF or On-board. If it gets trashed I would be up shit creek.
So I started thinking about screen protectors. The stick on kind that you use on something like the I-phone aren't tough enough for production, and I know of no other pre-made protector good enough for on set duty. Luckily in Seattle I'm very close to a few very nice custom plastics shops. So I made a date to pick up some tough plastic in order to make my own. Well it never happened.
I found myself in Home Depot today and wandered by their plastic section. Low and behold they had some 8x10" x .093" sheets of Lexan for $2.38. I'll take two please!
Two 8x10" sheets is enough to make 6 On-board covers and 6 covers for the rear LCD. THAT'S 39 CENTS A PIECE PEOPLE! Making a couple only took 10 minutes, and is dead simple. Hell, even Finner could probably do it.
1) Get some tools (see photo)
2) Trace the LCD onto the protective plastic on the Lexan
3) Score the longest line first, Use a matte knife then the plastic cutter to get the best results. You have to take LOTS of small passes at it to get a good score.
4) Snap the Lexan over a sharp edge. Use Vice grips with tape on the jaw for the thinner pieces.
5) Round the corners to match the LCD, and bevel the outside edge with some sandpaper. This is quicker than you think, 80grit will slaughter the Lexan very quickly.
6) Remove the protective plastic, and attach with the adhesive of your choice. Mine is Gaffers tape
Be sure to make sure the screen surface, and the back of the Lexan are nice and clean.
7) Stick the extras out of the way in your case, and laugh as you throw sharp rocks at your screen.
EXTRA CREDIT: Make a 4x5.65" size piece to use in your matte box as an optical flat. Just as good as Tiffen, and 1/200th the price!
HOW TO MAKE IT BETTER ('cause it ain't getting cheaper):
1) If your really cool, like REALLY cool (cooler than Finner and I put together kindof cool). You would use a Matte protective plastic like what is available here: http://www.tapplastics.com/shop/product.php?pid=349& OR this one: http://www.tapplastics.com/shop/product.php?pid=455& It would really cut down on glare.
p.s. Tap Plastics kicks ASS!
2) Find a fancier way to attach the screens. I've seen places use velcro around the edges but the problem with that is it makes everything much thicker, and lets stuff get trapped behind the screen.
