- Banned
- #1
When importing DNxHD quicktime files, I have the option in Avid of assigning RGB or 601/709 color space to the newly created imports. I've done a test importing DNxHD files and I can see that the 601/709 import option results in a higher contrast image with a histogram that is stretched out wider from blacks to whites. The RGB import test results in lower contrast image with a histogram that is slightly more "congested" in the middle of the range with higher values.
Given that these DNxHD files (from Red footage) have no color correction added yet, I'm wondering what the best starting place might be: the higher contrast 601/709 files with a wider histogram, or the lower contrast RGB option with more compressed histogram.
I should add that final output is NOT for broadcast. It's web and DVD and festival screening.
