Hot Mirror/IRND/Mirror ND Filter Matrix [Parts 1-4]
Evin Grant
Moderator
SoCal
www.evingrantdp.com
[7/23/09]
All four parts have been merged into one thread. You can find Evin's original posts within this thread here:
Part 2
Part 3
Part 4
~Brook
I'm posting part one now because I think it's info everyone in the market for theses filters needs to now NOW! Unfortunately it's bad news for some.
Part 1: Hot Mirror off axis color shifting.
One of the first things you notice when picking up any of the Dichroic coated Hot Mirror filters is the strong magenta/cyan cast the filter makes when you turn it around a bit. This is how the filter cuts IR, by reflecting, but it also has some effect on the visible spectrum most notably a cyan color shift that gets stronger the further off axis you look through the filter.
This is visible on all the Hot Mirrors to some degree or another but the Schneider True Cut IR takes it too far and unfortunately creates a strong cyan cast that is clearly visible on wider lenses like 16mm, even in normal daylight environments.
(These frames are unprocessed other than a color boost in Red Alert! The port-holing you see is endemic of the Zeiss 16mm T2.1 lens)
Here you can see the subtle effects of the Tiffen and Rosco Hot Mirrors compared to the garish Schneider.
It's relatively easy to correct a vignette in post but a color vignette is nye impossible.
Here's how the pack lines up...
1st place: Tiffen, slight cast off axis, probably negligible to 12mm
2nd place: Rosco, moderate off axis cast, probably negligible to 14mm
3rd place: Schneider, strong off axis cast, avoid all wide angle lenses!
Note: Although the Pancro Mirrored ND filters have no off axis color cast there is a slight darkening of the frame at the extreme edges that might accentuate vignetting slightly on super wide lenses of 10mm or shorter.
Here is a real world test done with the Schneider Ture-Cut IR and a Nikon D3 and 17-35mm lens simulating a 16mm and 10mm lens on the Red One in 16x9 mode.
(I don't have anything wider than the 16mm available for the Red right now but even that shows the dramatic color effect.)
Our flat light test in action...
I like Rosco and Pancro. Seems the right one to go. Thanks so much for the post Evin. Really need to know
A couple questions....
1- So these were the IR cut filters? Or were they the ND IR combos?
2- What exactly was the "color boost" in red alert? What was the amplitude of it?
3- Which ND's of the series were tested? Did you also test standard ND's, for a control group? Was there any color shift noticed when the color boost was applied to the regular ND's?
Don't mean to be a pain in the as*, just want the facts.
  • Thread starter
  • Moderator
  • #9
This is just part one, so be patient. There are still three more parts left to post. as far as what filters were tested here is the break down...
Pancro:
Mirror ND .6 and Mirror IR+ND .9, 1.2 & 1.5
Rosco:
TruColor IR Hot Mirror
Schneider:
True-Cut IR Hot Mirror
Tiffen:
Hot Mirror, Hot Mirror/IRND 1.2 Combo, IRND .6 & 1.2
  • Thread starter
  • Moderator
  • #10
The saturation setting in Red Alert! has a default of 1 which is not very colorful I tend to set it at 1.3 for normal shooting. To accentuate the color shift happening with the filters I punched that up to 2, it's highest setting. The point being that it would be very hard to discern the differences in the character of these color shifts otherwise. This is not an "artificial" color boost, this is the Red debayer program being told to decode and express the colors strongly. So no chroma is actually being added.
You can actually go much higher by typing the value into the appropriate field. :wink:
Would you mind posting a pic of the tiffen/rosco/schnieder @ 1.3? Not to nit pick, just wondering if a mountain is being made of a molehill....
  • Thread starter
  • Moderator
  • #13
Hot Mirror/IRND/Mirror ND Filter Matrix... (Part 2)
Part 2: IR Cut test
Before I start please let me give special shout out to Lite panels who graciously provided a special IR Lite Panel for this test.
http://www.litepanels.com
This was a very simple yet telling test. The IR Lite Panel is a small IR light source, it is invisible to the naked eye when on but produces a strong response on the Red One. Even with no ND in front of the camera it's very visible.
In order to have a true side by side comparison we, did, well... a side by side comparison...
First the IRND filters...
It's pretty obvious from the first frames that Tiffen's IRNDs are not really any improvement over the standard NDs. The Pancros are interesting because they seem to attenuate the IR in exactly the same amount as the visible.
The Pancros do seem to be doing a better job than the IRNDs over all.
Second, the Hot Mirrors
This test was very interesting, although the Schneider has the most impressive looking coating it is the weakest at blocking the IR spectrum.
The Tiffen comes in second with a respectable showing but the heavy weight champion is the Rosco TruColor which practically turns off the IR Lite Panel!
I also threw in the Pancro becasue it is kind of a mirror just not hot. It attenuates a bit but not as much as he HMs, you can see the Rosco + Tiffen ND 1.2 really doing the deed here. More on what this means in part 3.
Even the Nikon D3 has some IR sensitivity but not up to the Red One...
  • Thread starter
  • Moderator
  • #16
I don't really understand your question. Do you want me to grab a frame of the three filters at T1.3? What would that accomplish? This particular part of the test is not about IR per say, it's about the off axis, visible light color properties specific to the Hot Mirror filter designs. Anyway I only own T2.1 lenses so your out of luck on that.
Does this help at all?
Hold your horses guys, if you've ordered the Rosco already don't cancel, but if you haven't, wait till the field test and the conclusion before you dive in. It gets even more interesting.
What a tease! Thanks for the great test Evin. Very informative.
