Daniel Browning
That's very interesting. I've never heard that argument before.
Thanks, I enjoy sharing useful information.
So you are saying that given two sensors that are the same size and that process images the same way the one with MORE pixels will have LESS noise?
Yes. The greatest density of photosites are the most efficient and the lowest density are the least efficient. By that I mean the signal to noise ratio.
Larger sensors do not have a proportionately less amount of noise than smaller sensors, relative to area, which is light gathering ability. In other words, a sensor that is 23 times larger does not have that much less noise. As size drops, efficiency (per unit of area) goes *up*. More on this below.
Everything I've experienced myself and have encountered in the work of others seems to work counter to your argument. You state that the 1DsMarkIII has the lowest noise of any DSLR, but isn't the Nikon D3 the current low noise king?
The D3 is the per-pixel low-noise king, but the 1Dsm3 is the per-image low-noise king, by a small margin. Only the latter title has any meaning.
It has half the photosites of the 1DsMarkIII and achieves lower noise with less severe noise reduction. I'm just pointing to one comparison here but there are far more on the net with the same conlcusions: http://luminous-landscape.com/essays/comparison.shtml
Your edit is correct, this is the kind of flawed comparison that I was talking about when I said "People think smaller photosites are worse because they make flawed comparisons, such as viewing 100% pixel size instead of correctly resampling to the same resolution with a sinc algorithm".
To illustrate, imagine a 200 MP camera, let's call it ACS (I love Hubble!). If we compared 100% crops from ACS and D3, and the ACS had three times more noise, this flawed comparison would indicate that the D3 is better. Now imagine resizing those 200 megapixels down to just 12. The reduction in noise would be far greater than just a magnitude of 3, and the D3 would appear to be much noisier.
Now change the illustration from ACS to 1Ds3 and 200 megapixels to 21. See how it reduces apparent noise?
The comparison is further flawed by using inequal exposures (1/40 vs. 1/50), not accounting for Nikon's black point clipping (not apparent in their image anyway) or especially their chroma desaturation.
In it Michael Reichman reiterates the point that I thought was common knowledge: "The 1D MKIII's sensor at 10MP is closer to the D3's 12MP than the 1Ds MKIII's 21MP, and the pixels of the Nikon are bigger, so theoretically of lower noise. The D3 is also closer in price to the 1D MKIII than to the 1Ds MKIII."
The D3 is an excellent camera. I think it has as much as a full stop less image noise than the 10 MP 1Dm3, quite an achievement.
I thought that sensors with larger and fewer photosites were inherently less noisy than ones that are more denseley packed with smaller photosites.
Again, true at the pixel level but not when viewing the image as a whole. Another illustration of the 100% comparison flaw: take a beautiful 12 MP image: the 100% crops look great and the 8x10 prints look great. Now resize it to 21 MP. Add just a little noise in photoshop, enough to be visible at 100%, but not enough to be visible in the 8x10 print. Print both at 8x10 and compare: they are identical. But at 100% crops, one looks worse than the other.
In real life, are you going to crop a 4x6 out of your 21 MP image? Or are you going to resize it to 4x6 for printing? (People do all sorts of things online that they wouldn't in real life.)
Isn't this why 12mp digicams are far noisier than 6mp digicams at high isos?
A common misconception. Resize the 12 MP down to 6 MP and it will look better. Especially if the 6 MP is an older model.
Isn't this why Pentax had to reengineer the way their sensors worked in order to achieve the same level of noise in their 14mp K20d as they had in the 10mp K10d.
Right. Engineers are increasing density and efficiency at the same time. The big sensors are still nowhere near the digicam efficiency, but they've been following Moore's Law so far, which means we have a lot to look forward to.
Does the D300 have lower noise then the D3 then?
No.
You claim that people aren't resizing and resampling images properly when doing these tests. So why not try to compare images from cameras with the same number of photosites but in different sized sensors.
Let's compare the Canon G9 with the Canon 5D. Both 12 megapixels. The G9 packs 12 megapixels in 37 square mm. The 5D spreads itself out over a luxurious 864 square mm. That means the 5D has the opportunity to capture 23 times more light (a function of area). But does it? And does it have 23 times less noise? No, because it is far less efficient than the digicam.
Imagine someone took the Canon 5D sensor and wanted to make a 1/1.7" digicam out of it. So they got an exacto knife out and cut the center 37 square mm out of the 5D sensor and put it in a little camera. On that area, the 5D had 0.5 megapixels. But they're *good* pixels. If you look at the 0.5 MP image at 100%, it's clean and nice, whereas the 12 MP G9 image at 100% looks very noisey. Now resize the 12 MP G9 down to 0.5 MP... the 5D crop looks terrible in comparison. If you don't have an exacto knife, you can do the same experiment by cropping the center 0.5 MP in photoshop out of the Canon 5D. Thus proving that sensors can have *more* pixels in the same area to capture more light and less noise.
If they made the 5D with the same pixels as the digicam, it would have 280 megapixels. And by the time you resize that back down to 12 MP to compare with the real-life 5D, it would have a lot less noise. Obviously, they would if they could. But it dispels the fear that more pixels will mean more noise.
I know for a fact that the images I get off my 6mp DSLR are far cleaner than those that I get off of my 6mp Canon Powershot. Would you attribute this to the dslr having heavier noise reduction? I always thought it was because the photosites in the dslr were larger and less densley packed therefore generating less heat.
I have the same experience with my Canon DSLR and digicams. In addition to the comparison flaws I have explained, I think there is another big reason why so many have the misconception about dense pixels: digicams stink. They have small sensors and terrible processing (no raw, or if they have it it's dog slow). Thank goodness RED got it right.
