Mark L. Pederson
REDuser Sponsor
Okay -
One more time -
PLEASE PUT A RESOLUTION BUTTON IN THE SENSOR MENU
Here's why -
#1: right now, you have to access TWO separate menus to switch from 4K to 3K or 2K for slow motion - you should be able to go into ONE MENU - change the frame rate and change the resolution. Period. End of discussion.
#2: The most COMMON MISTAKE that creates DUPLICATE FILENAMES happens when someone goes into the PROJECT MENU to get to slow motion. They change the resolution - and then - it just seems logical to change the FRAMERATE right there - problem is - that frame rate is the PROJECT FRAMERATE - and if you turn it, and then turn it back, you RESET you REEL back to 001 - and this create a DUPLICATE FILENAME - MANY people don't know this.
#3: The solution is SIMPLE. Keep EVERYTHING THE SAME in the Project Settings Menu - simply ADD a RESOLUTION BUTTON in the SENSOR MENU next to VARISPEED. Now, your TECH can tell the camera department - "just don't touch the 'project settings menu'"
Thanks in advance for your attention to this matter!
One more time -
Here's why -
