"analog lenses" "digital lenses" backfocus
Manolo S. Navazo
44
www.manolo.pytalhost.com
i read here that some people are verifying/checking the backfocus every morning on his red, and some check on every change of location and change of temperature. this sounds to a very broadcast style. http://www.reduser.net/forum/showthread.php?t=8899
i mean if i got a collimated prime set(all lenses on 52,000mm)
1) does somebody had problems with the variable backfocus on red? in different temperated locations or just by moving/working with the camera. so does the pl-mount from red with his variable backfocus is rock solid? is it in pre-production test once collimated(also the lenses) neccesary to collimate it every day like in broadcast? or is like normaly with filmcameras.
what ever the answer is, i know an AC must keep in mind that something could move in micrometers, innerside.
2)somebody showed me an article in the newest "TV und Filmkameramann" an article about si-2k camera.
this production which was reported about, said that if you got a collimated pl-lens prime set (all collimated to the same 52,000mm distance) you have to collimate/change the backfocus on camera everytime you change the lens.
all those lenses for analog fotocameras or cine-pl-lenses got a focus distance for filmemulsion. with digital cameras we got now a glass in front of the chip/sensor.
so what the articel says is, that with every different focal lenght lens, you would get different distances in backfocus (also if all lenses are really collimated correctly by 52,000mm).
this should happen by the glass in front of the sensor which breaks the light, so every lens with different focal lenght should get different angle to the chip.
the article said, that "digital lenses" like zeiss digiprimes(only 2/3 chip) and fotolenses for digital fotocameras got it solved, in manufacturing a more parallel light pass trough the last lens elements. so you don't have to adjust the backfocus by changing the lenses.
i don't know if i should trust this article, i mean all "digital lenses" got an backfocus adjustment on lens, not on camera. in fotolenses it doesnt sound so important, because fotographers decide the sharpness by the eye, not the printed marks on lens.
so perhaps somebody could explain me, afirm or negate me, if i have to correct my backfocus on the red-one camera by every change of lens.
thx
a) does the variable backfockus on red-one camera is rocksolid?
b) does i get problems in different temperated locations with the backfocus?
c) does i have to correct the variable backfocus by changing a lens(if all lenses are collimated at same distance, perhaps 52,000mm)
d) does i get different flange back of the lenses because i got a glass in front of the sensor?
e):sorcerer: what would this mean for the new prime lenses from red
I tested few PL lenses on focus test charts (see my tests under the Lenses) and some lenses like Master Primes are very sensitive for back focus and some not, like super Speeds.
I can’t talk to the extreme temperature change -10F to 110F but from my experience the old worn out set of lenses may go bit deeper in to the mount (2 microns) also the mount itself (not RED mount) can be already worn out so add another (1-2 microns).
Also the tolerances the lenses are manufactured +/- 1.5 microns, so you can accumulate -5 /+2 microns of difference. MP have to be adjusted with 2-3 microns accuracy and most other will take up to 5 microns. So it is good to check BF once you rent the lenses for each and given set.
Did anybody rough handle your camera with the lenses on, lately?
And here you go why some people check BF every morning before shooting.
sorry andrew,
but what you say doesn't make sense to me to recollimate the red-one backfocus after changing a lens on set.
and to check the lenses and the camerabody in rental is fundamental, we are pro's not honky donkeys, right :)
so if you got differences by worn lenses you have to adjust it with shims on lens, or adjust it by the camerabody.
a good camera rental will give you all lenses in 52,000mm collimated, so there are still all my question i startet up.
thx
In my opinion i am going to check my backfocus on my RED everytime i go out on a shoot. I found out the hard way on my first paid gig with RED that the backfocus was out.
The RED's backfocus ring is awesome in the way it is easy to adjust B4 'tv' lens style but...once bitten twice shy'...it can obviously be knocked out.
hi bris,
and do you think you can make a 100% decision on set, by adjusting everytime your backfocus?, we still haven't 4k monitors. i am not talking about operators who pulling his own focus, i am talking about AC's who have to trust his measures and marks.
so if i am taking hands on this variable backfocus on set. i would never know if i am right on my marks or not. you could also do every time a measure verification, make a test shot, load in redalert or redcine, ... but this takes a lot of time.
nobody on set would give an AC the time to verificate after every lens change this procedure.
We set our back focus when the camera turned up & it hasn't drifted since (the mount is fairly bullet-proof). IMHO the Red's totally unlike an F900 or 750 where the back focus can regularly drift, requiring time-consuming checking & monitoring. It's a good idea to double-check your Red camera's back focus on your camera test day before it goes out on a job. We found a good way of checking back focus was to find a reliable lens that looks spot-on on a lens projector and put it on the Red at a certain distance away from a star chart and match the distance on the lens barrel (measuring the distance from the focal plane to the star chart with a Disto is the most accurate way). If your back focus is good the distance from the focal plane to the star chart should match the distance on the barrel and you'll have a nice sharp image on the monitor (only 720p of course). It also helps to use the zoom-in function on the camera. Shoot a little test and watch it zoomed in full-res in Red Cine - you probably won't be able to actually play it but you can view it as a still frame (if your back-focus is out, as ours was slightly when the camera first turned up, it should look fairly obvious). If it is out it's fairly time consuming to get it spot on and I wouldn't want to be doing that on set with everyone breathing down your neck - the best way is to check it on your test day and rely on it not to drift throughout your job. If you want to be super-keen at the beginning of each shoot day you could shoot a star chart at a fixed distance and check it in Red Cine at the beginning of the day but to be honest I think that's overkill - with experience you learn to trust the reliability of the mount.
This is all fairly time-consuming (much longer than checking back-focus on a F900) but the upside is that it doesn't drift (ours is 4 months on & still rock-solid!)
The RED PL-Mount is solid and by no means to be compared with a B4 mount. Nevertheless it's prone to temperature changes, meaning after 3 hours permanent running in a warm set (studio for instance) the backfocus starts drifting a bit. 1m is now 1.10m. A skilled 1st AC can compensate that though.
With a 35mm camera this does not happen since the mount does not get heaten up by the cameras electronics.
Hans
thats good to hear
Hans
holy shit, thats even better to keep in mind.
i like to see the AC who can compensate this, if you got in 1 meter differnce to 1,10 meters, than you would get in 10 meters a difference to infinity. it depends on the lens and aperture, i watched my kelly table with a 25mm lens and 1f (for example).
and if you got even a wider lens, there would be no way to compensate this, you will get a softer image, so no way for the ac to compensate the focus by pulling.
for me the only way to compensate would than be to recollimate the variable backfocus. and in 4k on set without 4k monitor or macbook to have a look, this would be a godforsaken situation for the AC.
and after all it would take time
Hans
Hans have you ever shot outside in cold -20C and then a few hours later move into a warm +20C interior? If you have I would love to hear your experience.
If others want to test this problem set your PL mount back focus at a typical room temp, then turn your camera on for four or more hours in a reasonably warm location. I am hearing multiple cases of the flange focal depth changing throughout the day with cameras throwing lenses off. Aluminum is appearing not to be the best mount choice. Not sure if it is just the mount or if the aluminum body is also attributing to the problem?
Hans
The RED mount IS similar to a B4 mount in the way you loosen off the locking screw mechanism then rotate the adjusting ring, then lock off tight. That's the way it works my friend.
I am learning to check via the methods mentioned in this thread at the start of each working day and when time permits try a check again or with a macbook. Not ideal but this is what we have to work with with the RED. In saying this when i did go to adjust the backfocus from the factory setting it was not done up very tight, but now it is and hasn't moved since. That's great news for the mount design.
But in also saying this, back focus checking should be the normal practice in preparation on a job.
..have you ever shot outside in cold -20C and then a few hours later move into a warm +20C interior?
If you're planning on doing that you'd better have 2 separate sets of lenses. One acclimated to the warm, the other to the cool. You'd be unpleasantly surprised to find your lenses completely fogged up for several hours when going through the temperature change you are describing. If you're smart you schedule to go from the warm to the cold environment as the lenses can handle that easily. Sorry to drift off topic...
Well Finner, aluminum has one of the largest coefficients of expansion for metals, meaning it expands and contracts more than most metals. From a theoretical point of view, over a focal distance of 50mm, and for a 100 degree Fahrenheit change in temperature, since the body is also made of aluminum, expect a change of 5.6 microns in the focal distance. Is it bad. I don't know. You are the expert, you have to tell me.
Besides, what about the lens barrel. Doesn't changes in temperature cause changes in relative distances between lens elements, in which case the problem is not limited to just Red in this regard.
Obviously, you want to let the camera reach the temperature of the surroundings and then adjust back focus. If the temperature is changing constantly throughout the day it seems you have two choices: Control temperature of the camera, short of that, adjust back focus periodically. Focal distance change is linear: 5.6 microns per 100 degrees F. You can observe temperature changes, decide how many microns change you can live with and decide when you want to check back focus.
Hope it is helpful.
I can go from outside shooting -30C to shooting interiors in a very humid pool in about 40-50 minutes. When you live in Canada you learn many cold temp tricks.
MANXLX,
That article got it wrong. You don't have to re-calibrate with each lens change. I discussed this issue with Alfred of P+S. But you might need more than one PL mount for the IMS, with each one optimized for a range of focal lengths. This is due to the digital cinema camera's focus sensitivity. Nothing to do with analog or digital lenses - there is no such thing.
On this feature we're using Zeiss T2.1 primes, optical designs that are decades old, and there are zero problems with the RED/Zeiss T2.1 combo. In fact the footage looks gorgeous.
I personally have experienced a change in the flange focus of a RED camera due to temperature change. The camera needs to be set up at the temperatu e it will be working at. A change of 20º F will cause a detectable shift in the flange focus.
That's all for now, I've got to get some rest, this movie is not in the can yet. I will post this weekend in more detail.
Till then...
Checking the back-focus is a standard procedure on ALL PL mount cameras (which before RED meant mostly film cameras). One would assume, wrongly, that all lenses are set correctly from the factory. Actually, we have checked several hundred lenses on a locked down RED with no temperature change and verified that many lenses are out, due to age, wear and tear or whatever. This is not just a camera issue. It is good to know exactly what you have, camera and lenses, prior to a significant shoot... just good practice. This is professional shooting, right?
We understand how important this practice is... which is why we made it so easy to do with our new mount. But don't think the RED mount drifts around easily. I would beg to differ on this point. I have checked my cameras many times and none have them have moved the slightest. But I still check.
Jim
Jim
How do you check? Coming from the digital world I have never done this. I understand the concepts but am unsure how to go about it. Has Red published a how-to sheet?
Hi Jim
Main complaint I have been hearing is that the reds FFD will change from the begining of the day after the camera is on for 4-6 hours. Seems like a slightly warm interior is where it is commonly being noticed. Hence the thought that the heat generated by the camera is causing the problem with the aluminum on the mount and possibly the camera body. If this is indeed happening then this is quite a problem. Checking FFD every 3 hours on the same set is not a good answer.
Please note these are complaints I have heard from trusted pro's. Maybe you have tested this or would be interested in trying it? I would really like to check this myself but my camera is stuck in this hold pattern thing (You wouldn't by chance have contacts or pull with a red employee or someone that could get me my camera quicker would you Jim?).
The best way is to do both a chart test and an infinity collimation test. But if you don't have one of those... the easy way is to mount your lens(es), set up a high contrast chart 6' and 10' away from the camera and light it so you are close to wide open on your lens. Loosen the screws and twist the mount until the image is sharp (should be at both distances). Lock it down. If you have two lenses that are different, you have a problem with one of your lenses that you need to know about.
If you focus by monitor (instead of tape) you will still be OK except at infinity if your back-focus is off.
Jim
Hi Jim
I have never had this issue on any of my 5 cameras. And I have run two of them all day in the sun at the races.
Care to tell us who your trusted DPs are? Sounds like they are guessing...
Jim
Like I mentioned I did not experience this but is something I have heard from two well established pro's that I trust their judgement that own cameras. Check this thread out to read about one.
http://www.reduser.net/forum/showthread.php?p=213850#post213850
From your response Jim I can tell that you would agree that if this is found to be more then just an isolated problem that it will be a major issue. I for one hope it is isolated to just a few cameras.
Please note this is not intended as an attack or red bashing by any means. It is simply bringing up a concern with what may turn out to be an odd problem with as little as 2 cameras.
