Dragging QTwrappers to FCP and timeline settings
Miguel "Macgregor" De Olaso
What are you guys doing when you have 200 shots in 200 subfolders and you want to drop just the H QTs in the sequence?
Is there a way of not picking one by one?
Also what settings are you using in the sequence in order to achieve 25fps at HD res.
I use spotlight in the finder.
Just go to the top folder, write _h in the spotlight field, and select "Filename" and the top foldername from the options bar.
Alternately, you can use Find in FCP (while the browser's the active window) and look for "_H" and click Find All - this gives you a new window with all the _H files in the project (or a specified bin) in one list.
EDIT: As to 25fps playback at HD, haven't had it yet with our quadcore. Going to post a new thread on that subject right now.
