Hi - as most newer monitors with 2k (or I guess HD if necessary) resolution and 4:4:4 color cost quite a pretty penny can one recommend a good used crt. I bought a pair of 22" lacie monitors used for 2D photoshop/illustrator work for $500 a couple of years ago. Real estate is not much of an issue so size does not matter for me. Any suggestions ?
thank you in advance - it is a real pleasure to be able to depend on such an informed and open community of professionals - I hope someday I can contribute in kind - around the end of july I will be getting my own camera, the wait as many of you can remember is excruciating
cheers
the ecinema DX looked very nice...closest I've seen to a CRT. They are handmade though so the wait is long to get one.
There are a number of problems that small shops face in maintaining image accuracy from point of capture through the finishing process.
Agreed, wall color, lighting, etc are all important factors, as is making sure no one fiddles with things unless it is overseen by someone who is in charge of making adjustments. Even once you get this part of the equation down, you still have to have a monitoring solution that gives you an accurate image (I realize accurate can be subjective). This means that image integrity is maintained from the point of capture (or importing if using RED) through the editing stage (if this will be your final footage), and into the finishing stage (color correction/mastering). You'll need clean signal path from your card's output, so if you have patch bays, boosters, etc in your path, they need to be of high quality. And finally, when it reaches your display and you are making important creative decisions in terms of luminance and color you want to have confidence these changes reflect reality and not the reality of the way the monitor was incorrectly set up or the perhaps the reality based on the limitations of the monitor.
Those are the challenges I see for people wanting to finish at a high level using low end gear.
I've been looking at the Panasonic TH50-PF10UK plasma with the SDI input board as a grading monitor, any comments?
I'm not doing film outs. I'm talking about HD finishes which is what a lot of small post houses are dealing with.
really bad idea.
btw- SDI input is Standard Def
Then you will have to deal with "Double compression artifacts", actually tripple since the camera is compressed.
Cable companies seem to be re-compressing HD for broadcast, so your monitor of the final compression will not predict what the viewer will see, the image will look too sharp or clean since the re-compressed version will get mucked up in various ways, so experence with the full system would still be needed to guess what the end result will look like, and since it is going to any old TV set rather than a fixed thing like film, the variables in the final look are even greater. I would use more than one monitor and try to guess how much worse it will look when re-compressed later...
Sorry, I meant HD-SDI
Can you expand on this?
