Jagger Christian
What are the lines of resolution for the Scarlet at 3K?
What aspect ratio would that be?
RED refers to 4520 as "4.5k." 4096 is 4k, 3072 is 3k. If Scarlet was 3.5k, they would call it that.
But -- and the reason I say "not so fast" -- is that it all depends on the lens too. There are many, many things that go into the ultimate final image, which include the sharpness of the lens, the performance of the OLPF, the sensor design, the demosaic process, all sorts of things. Red One can be given more of a flat-rate "78%" figure because you can mount the finest lens in the world onto it, and thus optimize that portion of the imaging chain. With Scarlet we're going to be using a fixed lens, so that 78% figure may not hold for Scarlet -- it's potentially limited by the sharpness of the fixed lens. Perhaps Scarlet will have a sharp-enough lens to give us a full resolved 78%, perhaps not. We don't know and won't know for a year.I think HardRockCA was interested in the basic aspect ratio (which is most likely going to be 16:9) and we already know (thanks to Graeme) that the sweet spot of resolving the RED's Bayer is 78%. I think this is a fair assumption and valid speculation...
The 3K recorded format is already a known quantity, given that the Red One uses it. I guess it's possible they would change that for Scarlet, but frankly the thought had never crossed my mind; 3K should be 3K as far as a standardized recording format goes.What buffles me is that You have used the words "will be" in regards to the recorded format.
Red One's SENSOR was 4520, but its recorded format is 4096.Given that 4K Red One was not 4096, but rather 4520 (h), how can You be so sure 3K Scarlet is going to be 3072?
HardRockCA - feel free to correct me if I have misunderstood what You are asking for...
I have few questions myself:
I am sure RED ONE has a "true" 4K recording mode (i.e. 4096), but how do You explain this "official" specs:
Full Pixel Array: 4900 (h) x 2580 (v)
Active Pixel Array: 4520 (h) x 2540 (v)
That's pretty much it Pete! I just wanted to know what I could expect as a final full rez product from the camera, if I used the Scarlet at it's full potential and what aspect ratio it would be at.
No fighting, I'm just trying to point out that (as in so many things) there is no easy stock pat answer. The answer, as almost always, is "it depends."I am not trying to fight with You Barry - You are absolutely right about the lens being part of a bigger picture, etc...
Okay, case in point. Here's the deal: SENSOR PIXELS HAVE NO RELATIONSHIP TO RECORDED FORMAT PIXELS. It's unfortunate that we even use the same term to describe them; it'd probably be less confusing if we used "photosites" to describe what's on the sensors, and "pixels" to describe what's in the recorded footage.I am sure RED ONE has a "true" 4K recording mode (i.e. 4096), but how do You explain this "official" specs:
Correct, but it does have everything to do with frame size. Which is why I said that the frame size would likely be the same between the Red One (in 3K mode) and the Scarlet in 3K mode.Red-Code on its own has nothing to do with resolution.
For recorded frame size, yes. For resolved detail, no. That's all I'm saying.I have never said it won't be 3K (3072). In fact I have specifically said it is going to be 3K (3072) OR more... A very fair assumption indeed...
Right. Scarlet is not a chip, it's not a lens, it's not a recording format, it's the grand summation of all those things. And every one of those is going to influence the final resolved detail. Which is why I say, we cannot know what the actual resolved resolution will be. Not until we can test an operational Scarlet and see what it actually produces.Notice he asked "Scarlet" not the "f/2.8 zoom lens".
Scarlet is targeted for 2K delivery (2048x1152) in 16:9 format after accounting for all the bayer processing and other things You might "do to it" in the post. This will allow for direct scale to HD master (1920x1080) or "cropped" DCI master (2048x1080) without any loss of final quality. 2K is the "sweet" spot of 3K bayer sensor and besides the only delivery format larger then 2K-DCI or HD is 4K-DCI - which is clearly not intended Scarlet's playground.
Ipsis verbis.
