geoff tompkinson
I've been shooting in the field in Italy for the last three weeks using Dougs Nikon mount with a few Nikon manual lenses.
Everything works fine until you try to do some long exposure stuff in bright light.
If shooting at 1fps with a 1 second exposure the results can be completely fogged by light leaking into the sensor chamber from the area of the mount release mechanism.
For this to happen badly the sun needs to be in the right place to strike this part of the lens mount directly. Not difficult on a sunny day.
I have had to resort to using one of those black scrunchy things girls use for their hair. I wrap this around the lens and roll it back over the mount once my aperture selection is made. Works well if a little cumbersome.
Under normal 24fps shooting the effect is not noticeable but I suppose it might still impart some decay to the the contrast of the image.
Obviously the ratio of light levels between the leaked light and the lens transmitted light increases in favour of the leak the longer the exposure times are. This is why the effect is bad at 1sec but barely noticeable at normal exposure times.
I haven't had chance to send Doug and e-mail about this but hopefully he will pick up on this thread.
Geoff
Geoff
