Craig Meadows
Well I got lucky and found my original O'Connor 50D in storage, no leaks and the action appears to still be good. However I am puzzled by what bowl size is needed for it. Thought for sure it was 100mm.
Reason I am confused is that I also have a 3193 Bogen-Manfrotto set of sticks I wanted to use with the 50D. The bowl on the sticks is advertised as 100mm. But, the 50D doesn't fit in it well at all. The 50D has radiused edges or fingers that make up the surface that contacts the bowl and only the smaller lip fits leaving no bowl action. 100mm is about 4", 75mm is about 3". When I measure across the top of the bogen bowl it's at 3-1/2". An older hi-hat that I used with the 50D measure a little over 4".
Any ideas? All comments welcome, thank you.
