- Thread starter
- #21
Peter Majtan
- Feb 29, 2008
- Tokyo, Japan
- www.petermajtan.com
A) RAID 0 you have 30% more speed, not double.
RAID 1 you may have the same speed if there is a well designed controller.
Is in RAID 5 where you decrease the performance, because the calculation of parity bits. RAID 1 hasn't parity bits, is just a mirror.
and of course, it should be HW controlled because is an external drive connected to an eSATA bus.
Dude, dual drive RAID-0 gives You pretty close to double (maybe between 190~195%) rate of a single drive, not 130%...
RAID-1 can be HW, but it can also be SW (especially on mac). And I have clearly said that You would get almost the same speed (~100%) of a single drive.
cash test: DVD_taiyo, DV_Exellence, HDD_Seagate, BR_MCC
DVD - 0.10 $/GB
MiniDV - 0.25 $/GB
HDD - 0.13 $/GB
BR - 0.60 $/GB
Why people always think $$$$/GB as the only factor when it comes to ARCHIVE/BACKUP? By far the most important factor is longevity of media. How about:
DVD - 2 to 3 years at best
MiniDV - 12 years + (good tapes do 25+)
HDD - 5 years max, but drop it once and say goodbye to your data
BR - early to say, but would not expect more then 2 years
Also - with all optical media - scratch it and is almost the same as dropping HDD...
Tape - You can't scratch it by handling it, You can drop it from a roof of a building if You want and still be able to read the data...
THIS THREAD IS ABOUT MEDIUM to LONG-TERM ARCHIVE SOLUTION, not online, or near-line (short-term) ones...
