Zach Nelson
- Aug 22, 2007
Some of my background is in theatrical lighting so I'm down with dichroics and the RGB processing approach of color cameras, ie. the bayer pattern. I'm wondering why in 2008 we still "waste" the surface area of our sensors. It seems to me that we should have a better method for measuring light than the CCD/CMOS technology from the 60's.
What if:
Instead of appropriating a diode to measuring a single RGB value we developed a "smarter" diode that could measure light intensity (as an electrical signal or resistance) for a given wavelength being sampled?
In other words, in a single chip arrangement you're assigning a diode (pixel) to measure a single RGB value and then in the case of the bayer pattern you process the result and create the final image. In the case of a 3-chip camera the entire surface of a chip is dedicated to a single color but it's 3 times as expensive and consumes space.
How cool would it be to have a circuit that could sample a diode's response to a given wavelength (measure intensity) but the wavelength was variable?
If you're familiar with the newer DLP projectors they have more than the simple RGB dichroic filters, they have intermediate wavelengths to help reproduce a higher gamut of colors. Inkjet printers work the same way - 6 colors instead of 3.
So in theory you could sample the entire surface of the sensor for 650nm (red), 510nm (green), and 475nm (blue) .. but also any wavelength stop along the spectrum from 400nm to 650nm. Maybe an RGB/CMY would produce a higher-fidelity image, who knows. If it takes .01ms to sample the surface for a wavelength then you're in good shape.
Maybe it's just a pipedream or maybe in 20 years we'll see something like this in use. I'm hardly a physicist so I don't know how diodes could be made wavelength-aware and specifically make the wavelength sensitivity controlled via a voltage.
You know, if diodes and circuits were fast enough - incredibly fast - they could, in theory, measure the zero-crossing of light as the wave energy hits the sensor and therefore calculate the wavelength and intensity. In this case you have a sensor that can measure all wavelengths and report the intensity at each simultaneously. But again this is just me dreaming...
What if:
