Finally Cut Server!!!!
Hey I'm glad it's finally out... but as for execution? They bought this product from another company a over year ago and announced last year at NAB it would be available shortly, right? I'm pretty sure I was sitting in the crowd when they were showing it and Color off.
Well ... if you are familiar with the previous products - Proximity Artbox Workgroup and Artbox Enterprise ... and you take FCS for a drive ... maybe you will understand what they have been up to for a year.
are you coming to the REDUSER WORKFLOW EVENT at NAB?:devil:
no, got to work on my nazi-gold doc. The reason why I asked was this:
http://www.apple.com/finalcutserver/specs/:
File Format Support (Scanning)
Video, audio, and graphics file formats
Animation NTSC
Animation NTSC Alpha
Animation PAL
Animation PAL Alpha
Apple Intermediate Codec (AIC)
Apple ProRes 422
Apple ProRes 422 Clip Edit Proxy
Apple ProRes 422 for Interlaced Material
Apple ProRes 422 for Interlaced Material (High Quality)
Apple ProRes 422 for Progressive Material
Apple ProRes 422 for Progressive Material (High Quality)
BMP
Dolby Digital Professional (Auto)
Dolby Digital Professional 2.0
Dolby Digital Professional 5.1
DV NTSC
DV NTSC 4:3
DV NTSC Anamorphic
DV PAL
DV PAL 4:3
DV PAL Anamorphic
DVCPRO HD 1080i50
DVCPRO HD 1080i50 with audio pass-through
DVCPRO HD 1080i60
DVCPRO HD 1080i60 with audio pass-through
DVCPRO HD 720p60
DVCPRO HD 720p60 with audio pass-through
DVCPRO HD NTSC
DVCPRO NTSC Anamorphic
DVCPRO HD PAL
DVCPRO PAL Anamorphic
Elementary Stream
H.264
H.264 Webcasting
H.264 10.3 Mbps
H.264 100 Kbps
H.264 100 Kbps Streaming
H.264 300 Kbps
H.264 300 Kbps Streaming
H.264 40 Kbps
H.264 40 Kbps Streaming
H.264 6.75 Mbps
H.264 800 Kbps
H.264 800 Kbps Streaming
H.264 for Apple TV
H.264 for iPod Video and iPhone 320x240 (QVGA)
H.264 for iPod Video and iPhone 640x480
H.264 for Video Podcasting
H.264 LAN
H.264 LAN Streaming
HD MPEG-2 19.0 Mbps
HD Uncompressed 10-bit 1080i50
HD Uncompressed 10-bit 1080i60
HD Uncompressed 10-bit 1080p24
HD Uncompressed 8-bit 1080i50
HD Uncompressed 8-bit 1080i60
HD Uncompressed 8-bit 1080p24
HDV 1080i50
HDV 1080i60
HDV 720p30
JPEG
JPEG 100 NTSC
JPEG 100 PAL
JPEG 75 NTSC
JPEG 75 PAL
JPEG Frame Proxy
JPEG Thumbnail Proxy
MP3 for Audio Podcasting
MPEG-1
MPEG-1 DVD 1.85 Mbps
MPEG-1 for DVD
MPEG-2 3.7 Mbps 1-pass
MPEG-2 3.7 Mbps 2-pass
MPEG-2 5.0 Mbps 1-pass
MPEG-2 5.0 Mbps 2-pass
MPEG-2 6.4 Mbps 1-pass
MPEG-2 6.2 Mbps 2-pass
MPEG-4
MPEG-4 Webcasting
MPEG-4 800 Kbps
MPEG-4 800 Kbps Streaming
MPEG-4 Clip Proxy
MPEG-4 LAN
MPEG-4 LAN Streaming
Photo JPEG 100 NTSC
Photo JPEG 100 PAL
Photo JPEG 75 NTSC
Photo JPEG 75 PAL
Photoshop
Pixlet NTSC
Pixlet PAL
PNG
Program Stream
QuickTime H.264 Clip Proxy
QuickTime Offline RT Clip Proxy
QuickTime Surround 5.1
SD 10-bit Uncompressed NTSC
SD 10-bit Uncompressed PAL
SD 8-bit Uncompressed NTSC
SD 8-bit Uncompressed PAL
Targa
TIFF
Transport Stream
Uncompressed 10-bit
Uncompressed 8-bit
XDCAM HD 1080i50
XDCAM HD 1080i60
XDCAM HD 1080p24
XDCAM HD 1080p25
XDCAM HD 1080p30
cheers, Fritz
I am not sure what's more fun - finding Nazi Gold or NAB 2008 - that's a close call -
Final Cut Server is fully scriptable and customizable -
We are still building an injest/on-set data-base application - and it will be a Red "front end" to FCS.
OBVIOUSLY Apple will add direct R3D support themselves as well.
:biggrin: huh, my nazi gold story is big fun... and thrill! I actually feel like becoming a part of one of those Henning Mankell novels... Thanks for the info! Sounds good for archiving. BTW did you ever get my e-mail (sent on march 10th)?
cheers, Fritz
(Friedrich Moser)
cheers, Fritz
(Friedrich Moser)
my PM is black hole - use mark (at) offhollywoodstudios.com
I hope it has an SDK, because Final Cut Server doesn't list Cineon or DPX as supported file formats. In fact it doesn't even list EXR or SGI-RGB which is supported natively in OS X.
Being Quicktime centric has it's pluses, but not everyone works in Quicktime.
I think Final Cut Server should just support everything Final Cut Studio and OS X supports natively.
Everyone who works in Final Cut (Apple's primary "Pro" application and the central point of reference for everything Apple does regarding manipulation of media) does.
No matter how they might guise it, Final Cut Server is designed to facilitate working with Final Cut and other Apple products. If it helps those who are using other software, well, that's very nice. But it's not its primary purpose.
All I know is that we've had many FCP editors bitch at us for providing TGA sequences of motion graphics... I don't have the user manual here, but I'll check it out next week.
Page 317 to 320 in the FCP user manual covers importing image sequences.
I'm using Final Cut Pro 5 as well, It works a fair bit differently then I assume Avid does it but it does work.
Final Cut 5.0??? That brings back memories ....
You REALLY want to be on FCP 6.0.2 or higher -
