2K/4K Windowed? huh?
Thundercross
What is this exactly, the 2:1 "windowed shooting" I have read about?
I thought the camera always shot 16:9 @ 2K 3K or 4K period.
Thanks, tried searching but came empty handed.
the sensor is 4k native so when you shoot 2k you get a cropped or windowed
version of the 4k sensor center cut.
Oh okay.. duh!:waaa:
I thought there was another set of settings I missed. 2K windowed is just 2K.
Thanks.
Read that wasn't sure about the "windowed" part....
Well, if you choose to record in the 2:1 aspect ratio, you are also cropping a bit off the top and bottom relative to the full 16:9 sensor. But I think that's normally called "reframing" or "cropping" or just "shooting 2:1 aspect" rather than "windowing".
So it has nothing to do with hard matting in-camera when shooting film?
Why would you want to crop more in-camera?
Yes, it's the same idea as a fixed 2:1 aspect frame matte in a film camera.
The Red One was released initially with only 2:1 aspect ratio recording enabled. Shooting 16:9 was enabled in a subsequent firmware update. However, currently, the "Red Alert" post tool, and the Quicktime codec do not work with 16:9 data, so this constrains some post workflows.
I'd guess once the post workflow issues are fixed, most people will choose to use the full 16:9 sensor.
Okay now I see why. :biggrin:
2:1
2:1
The 16:9 restriction in QuickTime is only for 4K resolution recordings.
Recording 2:1 reduces the data rate a little bit, but more importantly it lets you record slightly higher maximum frame rates in varispeed.
Hummm..
