Luis Otero
Has anyone tried to use an ExpressCard via PCMCIA adapter to record some footage from the Red? Is Red.com looking into creating an ExpressCard Module?:construction:
Basically, what's the point? ExpressCard SSDs are too slow, and SxS cards are fast enough but cost twice as much as CompactFlash, so -- why bother?
Just the opposite: use an adapter to be inserted into the Red CF Module that will allow us to use the SxS cards.
Quite the opposite. CardBus is capable of 1.3 gigabytes per second, way way in excess of what the Red needs.PCMCIA or Card bus is way too slow for data of RED.
Gotcha. Well, I do think it'd work. You can't use generic memory cards in a P2 or SxS slot, but I think Red has no such restriction, so it seems like you should be able to use an SxS card in an ExpressCard->CF adapter.The point is to have immediate access to a 16GB option, as opposed to be limited to only 8 GB...
But does such an adapter exist?
Do you think that the one on the picture I posted above would work
I give up...
Luis, a PCMCIA adapter isn't going to work at all. You'd need an ExpressCard to CompactFlash adapter. Basically the inverse of what's pictured in Andrew's post above.
Is this ExpressCard CF card reader above any good?
Looks like most people here prefer FW800 based CF card reader?
http://www.shopdigi.com/product.asp?pf_id=CFEXP
