Kevin Halverson
I'm planning to tether four Samson wireless microphone receivers (mini-XLR outputs on all of them) to my Red One, so this is important info. I won't be using phantom power, so does anyone know if the new RED XLR-to-mini-XLR cable adaptor (single cable with integrated adaptor) affects a non-phantom audio feed into the camera?
Yes, these adapter cables provide a number of features. If you plan on connecting your Samson wireless receivers directly to your RED ONE without using the RED supplied adapter cables, there are a few things that you should realize.
First, it is essential that you do not activate phantom power in the camera for any of the channels.
Second, without the cables, the Fs (clipping point) for the camera will be 2V RMS (+6 dBV or +4 dBU) as opposed to 6.6V RMS (+16 dBV or +14 dBU).
A 2 Volt clipping point is fine for most consumer line level signals, but you run the risk of clipping with many professional level signals.
If your Samson's offer output level adjustments, and you configure it so that you do not clip the converters in the camera, you are safe to proceed, but the warning not to activate phantom mode still applies.
Kevin Halverson
