Douglas Underdahl
- Jan 23, 2008
The shock wave just rattled my windows. Congratulations, Jim and RED team. And thank you.
Several days ago I had the opportunity to ask this question directly to Timur Bekmabetov. The answer was - nothing. They do some tests with red prototypes during filming Wanted, but there is not a single frame "shot on Red" in this movie.
On the other hand, Timur have very positive view on Red. He said that at the moment they filmed Wanted camera was too "raw" for real work, but for now Red is usable and keep growing quickly.
Before we left Prague, we took the footage shot so far and filmed them out. We scanned the film at 4k, and for every shot would follow with a 4k from the RED. Both were color corrected in the Baselight to match. I screened the results for Mitch and his team. They couldn't tell the difference. Seriously. And Mitch and Andy have sharp, sharp eyes.
Pretty much says it all. Whether any RED makes the final cut is irrelevant
I hope this clarifies some of the confusion of the Wanted RED issue and what the purpose of the alignment is.
Could you elaborate on this? Would that mean adding grain, reduce sharpness? Would be valuable info..
We were shocked when we analyzed the takes, (instantly I might add) and there was an amazing amount of detail in the windows and sky. More than the 5218.
Kjetil
By "dumb down" I am referring to the following.
FILM
1. We were shooting Kodak, 5218 film stock. Mitch, the DP, and the Gaffer Andy produced a great, balanced neg. And still they had a real gutsy style of exposing for the shadows and letting the highlights pop.
2. The blue record in this stock is very, very grainy. Essentially hellish for bluescreens. The green channel is beautiful - thus green screen.
3. DP's like 18. It's fast, and has a wide latitude. VFX people cry when trying to pull mattes from it.
4. When you scan Super 35 (35 full neg) and do so at 4096 h., you take a real sharp picture of the grain structure.
RED
1. The camera crew thought it would be telling to take the early RED prototype and point it directly into lights, bright windows behind our subjects, etc. Jim and Jarred, (and even myself then) were cringing. We were shocked when we analyzed the takes, (instantly I might add) and there was an amazing amount of detail in the windows and sky. More than the 5218. We had to clip the RED a bit to match.
2. The blue record on the RED images is quite amazing. Even a major improvement since we shot in Prague. The cameras we used later in Chicago sported a greater dynamic range and an even more improved blue record. In both cases, we needed to add some contrast and throw some data away to match the film response.
3. Pulling mattes from green screen using RED is much easier than film and frankly any other digital image and works much better than the Genesis system for instance. For a couple years people have been been saying that pulling keys from Genesis is easy. True, but only for the body of the key. The sharper edges means that when you do have a problem with an edge, it's real ugly. Instead, RED's 4k resolution defines the properties of an edge without the need of sharpening. The keys AND EDGES are stunning.
4. Ahhh. The grain. Do we add grain to RED images to be intercut? Or rely on the output stock? We did both. Pre-grain helped. However, I might add that if I were shooting a movie entirely RED, and the delivery was film, I would forget the idea of post grain and go straight to film.
Having said all that, film has been our standard. But now, we are seeing that we might actually be able to over-sample to achieve the 'film look'.
Hope this answers your question
best
j
Kjetil
FILM
RED
best
j
Thanks for the information, Jim & Jon.
Can you tell us if Red footage made it into the final cut?
