shutter phase and force reel
Rainer Fritz
48
Vienna
www.aacamera.org
Hi !
At build 15 Ver. 2.1.7 we have the following two problems:
When you wan't to adjust the shutter phase it has no affect in any shutter mode. Didn't try it with a second cam connected via genlock.
The adjusting of the shutter speed would be fine to change it in smaller steps then 1/s.
When we check force reel function it has no affect. After formatting the storage and activating the force reel function it took no affect when we hit the record button.
best regards
rainer
Hi Rainer,
With force reel you have to do the force reel first (effectively you are telling the camera what number to use on the NEXT format). Then format the card Voila.
Regards
Jeff
RED708
thx... we will try it... it seems that the cam is also showing now the coming take number in the display.... not the last as on build 13 when you in standby.
