Thor Wixom
If you had the option to put a P+S Technik mount on your Red, and then be able to swap out the Birger mount(s) just like any of the other P+S Technik adapters, would you do it?
If I well inderstood you, you're asking about the possibility to have our RED based on a P+S Technik adding the Birger Canon or/and Nikon, that is, both?
So, either the face plate would need to be replaced or routed out to fit the base IMS mount. So, personally, I'm okay without mounts like canon FD, leica m, and C-mounts, which have shorter FFDs than Canon EF, in exchange for less hassle. That's how I see it anyway.
But if it would work, great. Nothing like options.
1. Imagine pulling focus with a 50mm lens wide open at F1.0 on RED (that's the main reason to use it in the first place), in a scene with movement. Close to impossible. Plus, the focusing element on the Noctilux is nowhere near what we need for cine applications (very, very short throw).
2. A 50mm still lens will have the angle of view of a telephoto lens on RED. Therefore, pretty limiting in its application.
3. The FFD is so short for Leica M. The focus ring on the Noctilux is very close to the rear element, that means it will sit somewhere very close to the P+S mount. Impossible to put a custom cine focus ring there and again, to pull focus (all this, beside its short revolution).
I can imagine you can use Noctilux as a telephoto lens in a very controlled scene with no movement - sort of like the still candle-lit close-ups in Barry Lyndon.
There should not be so much A BIG PROBLEM pulling the focus on ultra wide open aperture of f1 as I am informed well.
50mm lens is 50mm lens on Leica 35mm or RED 4K.
For this "issue" we can always find a way to get things to work as we want.
Also for dialogs in a dark room, corners, cars, some other details of doing things in a dark space, etc...
Please correct me if I'm wrong here.
It's not about experience, it's about Physics
