Addonics SATA CF adapter reads 8gb CF in 3:15
Michael Morlan
Austin, TX
michael-morlan.net
Hi all,
I tried the Addonics SATA CF card reader on my quad-core PC today and am pleased to note it reads a full 8gb RED CF card in 3:15. Check it:
http://www.tomshardware.com/2005/08/18/accelerated_compact_flash/index.html
Notes:
From the above review: "One drawback of the Addonics device is that only the very latest SATA controllers and chipsets support the hot swap function. These include latest generation models from Intel (with ICH7 Southbridge) and the nForce4 from NVIDIA. This affects how you can use the cards; without hot swap, the system has to be restarted before it detects the CF card and makes it accessible under Windows."
My CF reader works flawlessly with my ASUS Maximus Formula motherboard's SATA ports set to AHCI (and Intel's Matrix Storage Manager installed.) Follow the rather complex steps noted in the following link to enable SATA hot swap on your PC:
http://forums.pcper.com/showthread.php?t=444831
Michael
esata expresscard macbook pro
Any experience using an eSata-Expresscard adaptor and this CF-Sata one to capture the footage with a macbook pro? Would it be more or less efficient than a fast CF-Expresscard adaptor?
How about using it to transfer to redundant hard drives on the other port of the eSata adaptor? Does anybody have any insight/experience about how this might work out?
Aside from the fact that a custom housing would be needed, but addonics themselves seem to have plenty of these.
I was thinking something along this
Addonics have some very cool stuff...
I could have sworn they had a little bay that takes 4x 2.5" drives in one 5.25" drive slot... Can't find it now.
If you get one of the Addonics Hardware Port Multipliers, it should work on just about anything.
I may try this....
I went through 3 card readers before I could find one that would unload my card in less then an hour(16 gig)
2 of them could never register there was a card in there at all....this is on 3 seperate computers...and one was a lexar pro reader..
I am considering a firewire 800 card for my pc, and then a firewire 800 card reader...bypasses the digital handshake that usb devices have to go through
but this addonics device should run at sata speeds...at least theoretically
right now I am lucky to get transfer rates of 7-9Mb per second...usb 2 should be able to do 60Mb/sec (480mbits/8) and the card itself should be good for 40-45...so there is something other becoming the bottleneck.
I don't think usb2 can do over 25mb/s, unless things have changed a lot in the last few months. I even think the bottleneck on the mac platform was somewhere around 18 Mb/s.
Sad, I know, and nowadays not even apple seems to be willing to back Firewire.
depends whether or not you are talking MB megabytes or mb megabits
it's theoretical limit is 480mb/sec
or 60 MB/sec
usb 1.0 was 11MB/sec
i just tested my fastest usb stick and it gets 16.3 MB/sec= 130mbit/sec...thats with a usb stick, i have a portable raid setup on usb that i can edit 1080p with no problem(cineform though...so maybe 35-40MB sec)
I doubt you'll ever see the full 60 MB/Sec though....
I tried a version of this.
First, I have a Dell XPS m1710 and use a LaCie Firewire Card. Off of the Red Drive its about 33MB/s.
I am trying out the addonics dual in the optical drive slot. I only get a 23 MB/s r/w. The driver needs to be changed for it to work properly though. Now just to find a driver that dell doesn't know exists.
I can copy a full 8GB card in under two minutes with this reader.
