Hasselblad lenses are designed to cover a 6cmx6cm negative.
Whats different about a 80mm medium format is that the projected image could cover a larger sensor if such a beast was available (Which it does like the phantom65. The FOV only changes because the sensor size changes)
I've also seen some PL mounts that connect directly to the hass glass, but I don't want to lose the ability to shoot stills with the lenses. Any suggestions?
Anyone know what's the best way to mount the hasselblad medium format lenses to a RED? I'm considering using a nikon mount on the hass lenses connected to the nikon mount on the RED. I've also seen some PL mounts that connect directly to the hass glass, but I don't want to lose the ability to shoot stills with the lenses. Any suggestions?
