variable shutter speed?
mattmiller
New member
53
i understand that the standard RED shutter speed is 1/48... my question is, is 1/48 the 'standard' because shooting at 24p is the standard? can you shoot at 24p with a shutter speed higher or lower than 1/48?
i've searched for the answer on google, but basically only found that 1/48 is the 'standard' for RED.
thank you,
matt
would this be true:
1/24th = 90 degree shutter at 24fps ?
Of course you can.
You can, but you better not do it on a Red (or other CMOS camera) if you're lighting with a magnetic-ballast HMI. Bad things happen as the shutter speed gets shorter, and there is no "HMI safe" speed where all shutter speeds work. Electronic-ballast HMIs appear to be much more compatible.
I'll try to post results soon, but basically you get huge rolling bands throughout the video if you take the shutter speed up to 1/192 or faster @ 24fps, and you get nasty flickering when doing VariSpeed mode at anything other than 24/30/60fps.
Barry, can you use a magnetic ballast with a Red at 1/60 or 1/48? I know a camera with a CCD (or film) could do both, but with a CMOS...I don't know?
Shutter Speed
Shutter Speed
Yes, full details are in the RED-ONE Operations Guide, available as a downloadable .pdf from the www.red.com/support web site.
Magnetic ballast worked at 24 fps @ 1/48 and 30fps @ 1/60, and 24fps @ 1/60. It pretty much didn't work on any frame rate or shutter speed when the shutter speed climbed above about 1/192, or the frame rate varied from 24/30/60.
Well, that's not ideal but it's not a big problem, either. No one's going to be doing too much high speed photography with discharge lights...but 36fps or 22fps didn't work, even with 1/60th and 1/48th shutters?
Anyhow, thanks for the info.
I didn't test every possible combination, but I ran through every shutter speed on 23.976 and every shutter speed on 24.000, and then I put it in "relative" mode in 23.976 and 24.000 timebases and ran through most every frame rate. In relative mode, only 24/30/60 worked.
So I don't know if 36 @ 1/60th worked or not, and I didn't try slower than 24.
Ah, makes sense. That's not too prohibitive; those are the "most important" frame rates anyway. Thanks again for the info.
Also, I tested using an electronic ballast'ed metal-halide "HMI" from www.coollights.biz. IIRC it was solid at all frame rates and shutter speeds up until I got up into the 1/1000 to 1/2000 range.
Are you guys saying that the Red exhibits flicker at HMI safe speeds, or are you just saying it flickers at non HMI safe speeds like every other camera ever made ?
Nick
No, I'm saying it makes big thick scrolling bands of dark orange, unlike any other camera ever made. (well, unlike any CCD or film camera ever made, but all rolling shutter cameras behave this way).
It's a new phenomenon, one that shooters may want to familiarize themselves with. It ain't flicker. (although, depending on the speed, you can get what looks like flicker, just not the same familiar type of flicker, this is instead a fast-scrolling band). It's different.
Fortunately with Red, unlike with film, you can see it happening on the monitor as it's happening so it doesn't come as a big surprise in the transfer.
The amplitude of these bands depend upon exposure time, frequency should remain constant, and the scrolling between frames (i.e., phase difference) is due to frame rate (beat frequency between frame rate and flicker frequency). Hence, if frame rate is matched correctly, then the scrolling should stop, but the static banding should stay there.
However, in theory, if exposure time is properly matched, then there is no need to match frame rate, as the amplitude of flicker has been made to vanish.
If exposure time is not matched, then the amplitude of the flicker is reduced by selecting a larger exposure time, though, at the expense of more motion blur.
i'm glad I happened upon this thread, because my sekonic only does (evidently) 1/30 and 1/60, there doesnt seem to be a setting for 1/48 (unless I am missing it? its possible, i'm new to this.)
I was hoping that I would be able to set my RED to either 1/30 or 1/60 so that I wouldn't have to always add or subtract half a stop on my reading... but I wasn't sure if the blur would be noticeable... or even if that would even work. i was also nervous that the amount of light between stops is logarithmic, so I was guessing that 1/48 would be (roughly) half a stop in between 1/30 and 1/60 in terms of exposure...?
obviously this is all a bit new to me, so any help would be appreciated.
thanks,
JT
Austin, Texas
I would beg to differ on this one. HMI is used because its so much more effective. For one, the Red likes daylight balanced light. I would hate to light high speed with gelled tungsten.... yikes, you'll catch the set on fire. You might need to look at using Phantom for those really high speed shots.
thanks,
JT
Austin, Texas
JT,
Please refer to the following graph, in which I have drawn integration time (exposure time) increasing on the x-axis and on y-axis is its effect on the amplitude of the corresponding "banding" because of flicker.
As seen, "flicker free" are those exposure times where the red line meets the blue line. In between values are where one sees the flicker and its magnitude varies. As seen, the magnitude of flicker decreases (even when not zero) as integration times increases (to the right).
BTW, since you are in Austin, you are most welcome to drop by any time and we can discuss such topics of interests.
I guess so...but this is a camera that "only" shoots 60fps in 3k (personally, I wouldn't use 2k for much) and that's 1/120 for the shutter, which should work fine. And if you are doing 120fps...just rent an electronic ballast for the day. I was speaking for myself, but I still think, universally, the rolling shutter should not be that big an issue even with discharge lights.
Also, I don't really see the point of lighting night interiors with 5600K. But if you need a super clean image, that's a fair point.
