How about a Operations Guide sticky?
Craig Meadows
Pensacola, FL
vimeo.com
Would it be useful to have a sticky for updating the Operations Guide? Something users and the Red Team could contribute tips to?
An example is the joystick as mentioned in a post in this section. The manual does not explain clearly from the beginning that to change values the joystick has to be rotated.
Another might be the wing nuts. I didn't know until I read here that they are spring loaded and can be pulled out and then re-engaged to tighten when close to a bracket or the body.
I think contributed tips would greatly help in fully developing the manual.
Or it could simply be a "how to & tips" section for little things that people have discovered along the path to RED enlightenment. :)
Guide
Guide
Great Idea.. I second the motion !
The Ops Guide on RED.com is always the release build. The beta build does have the beta build's version of the Ops Guide in it.
Another two things, I have a sticky with info for when you just get your RED ONE. if you have any guidance for something to add, PM me.
Lastly, we are also working on a Quick Start Guide download this is focused on getting your camera rigged for the first time.
BC
