Proxy Clarification
Jeff Brown
London, UK
Chaps,
Been playing with 2k H proxies in FCP. I did a split screen comparison of the H proxy with a Redcined rendered 2k prores version of the same shot. Now I know the H proxy is supposed to be 1024 x 512. My rendered version is 2040 x 1024 and in my timeline the H proxy is scaled 200% to match. The thing is they appear to be of exactly equal quality when rendered to prores. No sign of aliasing/compression etc. (with the M and P proxies it's really noticeable)
So what is going on here? The H proxy references the 2k .r3d so is it scaling its decode to match? Ideally I'd like to finish from the proxies and avoid transcoding to get a 1080 finish - the final destination being web based. So if I scale up my 1024 x 512 how much quality am I really losing?
On another note if the proxies are 8 bit but I convert my sequence to 10 bit prores and render am I effectively then creating a 10 bit sequence from the .R3d reference or is the 8 bit baked to the proxy?
Thanks in advance for feedback on my ponderings.
Cheers
Jeff Brown
#708
What build are you on. In 15 the _h proxy is upped to 2048x1024 (i was on build 13 with _h equaling 1024x512) which would explain why the quality is equal to the prores'd 2048x1024. Check your proxy resolution.
My real question is - DO WE KNOW DEFINITIVELY THAT PROXIES ARE ONLY 8BIT??
In all the side by side testing i've done, between proxies and redalert outputs - i see no difference in quality.
Proxies will be 32bit float when you set FCP to high precision yuv in settings->video processing.
Thanks for confirmation of the 32bit float.
Regarding the proxy size - I'm on 15.2.1.7 and on my 2k my H proxies are still 1024 x 512. I know there's now an F proxy but that currently doesn't work with anything. Do we know when that will be enabled?
Also, Deanan any confirmation on wether the H proxy is scaling in my timeline (it looks as good as the 2048x1024 prores) or is it definitely locked to 1024x512 and I just can't tell the difference!?
Rgeards
Jeff
_H proxies
_H proxies
Rgeards
Jeff
Did you shoot the original .r3d at 4K or 2K?. And are the proxies from the camera? The _H proxy should always be always half the original .r3d pixel H and V size.
_H proxies
_H proxies
Hi Stuart,
I shot 2k .r3ds and am using the H proxies (1024x512) in a timeline that is 2048x1024 - so scaled to 200%. FCP is set to high precision rendering YUV and rendering the sequence in proresHQ.
I'm doing this to compare the quality difference between rendering out a 2K prores from redcine and working from the h proxies.
To my eye there appears to be little difference in terms of resolution/aliasing although of course the proxy is a more contrasty image.
I was really just curious to know what the proxie is doing and weather it is fixed at 1024x512 or weather it scales on the fly
Cheers
Jeff
#708
Did you render your RedCine ProRes file at 'Full' or 'Standard'?
If Standard, then RedCine is effectively using half the 2K resolution (hence looking like a 1024x512 image scaled 200 percent).
If Full, then RedCine is using all the resolution - where it should look better than the 1024x512 upscaled.
When shooting in 2K, it's imperative that you render 'Full' out of RedCine to get the best looking images. When the '_F' proxies work, then at least you'll be getting all the pixels from your original footage.
Hi Kenn
Tried it with full demoisaic from Redcine. The difference is negligible I feel - I'm thinking for SD / Web destined projects it may be a quick and easy workflow that avoids the full trranscode times..
Full size proxies would be welcomed and of course if I can get Crimson working OK....
Cheers
Jeff
_F, if it works on some systems (i believe leopard and the latest codec), is a scaling being done by QT. Proper _F support will likely appear in about 3-6 weeks if all goes well.
I believe I'm on the latest version of the codec as well as Leopard and the _F proxies don't work for me.
Bring on Build 16 and the new apps!!!!! :)
difference between 2k proxies and 2k Pro Res out of redcine?
its not 8 bit vs. 10 bit, right?
its not the resolution you say?
So what is the difference?
-----more precise : how are the proxies defined?
Sorry Deanan - didn't quite get what you meant in that last post. Are you saying that my H proxies are scaling in QT in this instance? So although its 32 bit float I'll still have aliasing and so an inferior image to the prores I create in Redcine from a full debayer. Have I got that right?
I'm latest codec and Leopard with latest graphics update and I can't get F proxies working yet.
3-6 weeks is cool. Looking forward to it.
Cheers
Jeff
Bottom line for _F: Don't use them right now. The fact that it works on some systems is just a coincidence and is totally unsupported.
Bit depth is separate from resolution so if you're using the proxies, they will be lower quality than doing a full debayer and scaling down. For some workflows, the proxies are completely usable as half res high quality. For other workflows, a full debayer is necessary. RedAlert also has a half res debayer right now which is a high quality debayer that's alot faster than the full res debayer but but very close in quality to full res debayer.
So in order of quality for a 4k source and 2k output:
1. Full res debayer w/ a down scale.
2. Half res debayer direct to 2k (redalert only at the moment)
3. _H proxies
"F" works on my system! Just tried it. Pretty wild seeing it fill my 1920 monitor with 1/4 of the image! Plays at about 12FPS or so with audio.
Mac Pro 2 x 2.66 Leopard 10.5.2, 7GB RAM, QT 7.4.5.
