120 fps not showing up
If someone could point me to what I'm overlooking. I've installed the newest firmware build and tried with the Red Raid and the CF card as media. I'm still getting capped at 59.94 fps at 2k 2:1. Is there another setting I need to get this working? Thanks!
are you doing it via varispeed menu or via project format settings. probably the latter. set the project to 24 then change it in the varispeed menu
need to set project frame rate to 23.98 or 24 or 25
then go to sensor menu
then right to variable speed menu
make sure red raid is connected and mounted
click varispeed then push jog
then right twice to speed
set frame rate to 120 by spinning the jog clockwise about 1 million revolutions (jk)
go back to vari speed (over left two)
unclick then click vari...
120 should show up in yellow on lcd in the top left corner or evf as the new frame rate, but your project frame rate will always show up at 23.98, 24 or 25 on the back status window as it is the playback framerate.
good luck and happy shooting...
That's it. Thanks! :)
