Axel Mertes
"Specs can change at any time". But anything over 4520x2540 would have to be a different model. This is the largest size we could ever go to on the RED ONE.
This comment is not to encourage rampant speculation. Just pointing out a fact that the sensor and system architecture of the RED ONE tops out at 4520.
Jim
Jim,
as we experience some flood of new formats these days (no worry, I like them) but so many applications having different requirements, what about implementing a real custom resolution mode?
Right now we all know that there is a fixed maximum pixel bandwidth of the Mysterium sensor, which I'd calculate as roughly:
4520x2540y60Hz as physical limit, ie.:
4520 * 2540 * 60 = 688,848,000 pixel/second.
The next limit is the REDCODE encoder limit, which currently peaks at 3K 2:1 60Hz as it appears to me:
3072 * 1536 * 60 = 283,115,520 pixel/second
which apparently equals 4K 16:9 30Hz:
4096 * 2304 * 30 = 283,115,520 pixels/second
while 2K 2:1 120Hz is less data, as we can see here:
2048 * 1024 * 120 = 251,658,240 pixel/second
Finally we have the line speed limit, which is:
2540 lines @ 60 Hz = 152,400 lines/second from theory,
or:
1024 lines @ 120 Hz = 122,880 lines/second from practice.
I'd summarize:
1. Limitation: Sensor pixel speed:
2. Limitation: Codec pixel speed:
3072 * 1536 * 60 = 283,115,520 pixel/second (hopefully not the max)
3. Limitation: Line speed:
The above 2. and 3. are real world proved values, while 1. is an given value from specs. Clearly other factors may influence actual speeds. Values can be even higher (which I hope for the codec limit) or lower.
So as we clearly hope for 4K 60p at some point (inspite of a 2K scaled as you requested us some time ago, but recently stated "[surely] not until NAB"), we can at least identify that within above constrains certain custom resolutions could be possible, maybe with some nurdish increments of 4, 8 or 16 lines as size multiplicators, but at least possible.
Having worked with lots of industrial cameras, I see technically no big reasons to not have user defined custom modes within these constraints.
What could be an issue is how a custom mode is displayed / refreshed on the LCD/EVF/HD-SDI/HDMI path. But if one would agree that a 2K 2:1 120Hz is already far out of question to be in any way compatible to any of these output ports, its already the solution: Treat it as if you were treating this high speed 2k 120Hz format.
So given the above facts, slightly including some speculation (but minimal as I think), we should be able to do some interesting custom modes, such as:
High Speed thoughts...:
2048y @ 60 Hz maximum, maximum width then ~2304x (nearly 1:1 mode)
1536y @ 80 Hz maximum, maximum width then ~2304x (a 3:2 mode)
1200y QXGA @ 102 Hz maximum, maximum width then ~2312x
1080y HD @ 113 Hz maximum, maximum width then ~2316x
1024y SXGA @ 120 Hz maximum, maximum width then ~2304x (hey, more than 2:1...)
800y XGA @ 153 Hz maximum, maximum width then ~2312x
720y HD @ 170 Hz maximum, maximum width then ~2312x
576y PAL @ 213 Hz maximum, maximum width then ~2304x
480y NTSC/VGA @ 256 Hz maximum, maximum width then ~2304x
288y PAL one field @ 426 Hz maximum, maximum width then ~2304x
240y NTSC one field @ 512 Hz maximum, maximum width then ~2304x
128y YouTube style @ 960 Hz maximum, maximum width then ~2304x
NEW:
Other format wishes collected from other threads:
4520x1884y 2.40:1 cinemascope
4520x2443y 1.85:1 academy widescreen
3048x2540y native 2.40:1 anamorphic 2:1 cinemascope (ie. 1.20:1)
1920x1080y native HD
3072x1850y 1.66:1 widescreen
and the list goes on and on and on...
Comments welcome!
Axel
