Häakon
Hi Jim,There will be a special build for 1080P (and 720P). But it will NOT be scaled.
We are doing this because our customers think they want it. We see no reason... really. But we heard it long enough to put it on the list.
I honestly think a lot of the frustration with this back and forth is due to misinterpretation of people's comments.
I don't think anyone has ever been asking for a cropped 720 or 1080 format. The whole point to having a 1080 version in-camera was to acheive higher fps from the full sensor than shooting in 4K onboard can give us (which, again, limits us to ~30p onboard) while keeping 35mm DOF, FOV, and relative resolution. You keep stating that "the frame rate of full frame is fixed at 60fps. Period." But we can't GET 60p from the 4K format onboard. THAT was the whole point of the scaled formats. The original feature list indicated that the scaled formats would allow for up to 60p from the full frame, and 1080 scaled-from-4K footage would cut together with other 4K native material much more nicely than than the only other higher fps option at the time - 2K windowed. Thankfully, the inclusion of 3K windowed is a decent compromise and should help this situation somewhat, even if we still can't use the entire sensor to achieve 60p.
Now that you have made your position clear that you have dropped development of all scaled modes entirely - regardless of the reason - I think you should re-ask the userbase if they're interested in a 1080 or 720 *cropped* format. Perhaps when 1080 was mentioned a long time ago, some people were assuming it would be scaled while others were thinking such a format would be windowed and were having a hard time understanding why anyone would want it. I can only agree that offering a format which cuts out 80% or more of the sensor's total resolution is next to useless.
1080 monitoring output, on the other hand, would be a drastically welcome addition.
