Steve Gal
It sounds like it could be a simple back focus adjustment.
Although, I have yet to see a RED 18-50mm and I am not certain as to how the focus mechanics work.
Matthew, the rear shims are exactly the same as the Cooke S4's so I tried to use the Cooke shim in the Red 18-50 but although they look the exact same, the inner diameter of the Cooke shim is just a hair smaller and would not fit. I guess I should order some shims from Red to have for these 18-50 adjustments. I usually just make my own shims but these are not so simple design. I have not played with the front focus and I hope that is an easy adjustment like most other zooms.
