- Moderator
- #41
Evin Grant
Moderator
- Dec 28, 2006
- SoCal
- www.evingrantdp.com
Oh yes. No change.
Now THAT is what I am talking about!!!As things develop, we'll release a look xml file format and provide support in RA, RC, etc.
You should only use the phantom power if you have received the new upgraded mini-xlr to full size xlr cable.. if you still have the old mini-to-mini cable plus separate mini xlr to full size xlr adapter, dont use phantom power until you get the replacement from us.
* 4K _F, _H, _M and _P QuickTimes may crash QuickTime Player.
* Dual Link HD-SDI outputs replicate HD PREVIEW or PLAYBACK HD-SDI signal.
only when using phantom power ( for now ). You can use 3rd party XLR cables right now if your microphone uses an alternate power source ( AA battery, etc. )
reformat card in build 15, see if that helps.
This new build is not letting me shoot 23.98 fps 4K 2:1 RC36 to CF card. I'm getting "Media too slow" when I try to record. I was able to record this no problem in build 14.
Any ideas?
I got the same message and by reformating, it works!:gun:
Luis
That's pretty interesting. So basically the cleanest way to use the XLR inputs and phantom power is via your adapter to a standard XLR cable. Can you shed some light on what you guys are doing so 3rd party guys could make us up cables? Or is this something that's going away soon so it's irrelevant?
Thanks!
None of the 2K settings give me the 120 fps choice. Any thing else needs to be changed?
You are in the Varispeed menu, right?
I'm fairly sure we got the new upgraded min-xlr to full size xlr cable. Cuz that's what it looks like: a 4" cable with mini xlr at one end and full-size xlr at the other.
Evin do you have the ghostbuster sign thru valid setting? I've got that through all 4k options in RC36.
goto Varispeed.. and remember, 120fps 2k only works when recording to Drive.
