I wonder if this will be a problem with Dedo lights? They are DC powered.
DC is never a problem. In fact, I've shot several times with my Dedos with no flicker at all.
Christopher, you're living in a 50 Hz country, so did you shoot with a 1/50th shutter? 24 fps at 180 degrees is not technically a "safe" speed for 50 Hz lights. See:
http://www.panavision.com.au/Information/Flickerfree50Hz.htm
You should either be shooting at 24 fps with a 172.8 degree shutter or 25 fps with a 180 degree shutter to get 1/50th.
Unless you are saying that you did that and still got flickering from the streetlamps.
As I mentioned before, for a rolling shutter sensor, the "flicker free" exposure time is:
n / (2 * line freq).
And, for the worst case flicker the formula is:
(2n + 1) / ( 4 * line freq)
Could you explain the math behind these formulas? My inner nerd needs the dirt.
(I'm noting that the second formula gives 1/48th as a "worst case" for 60Hz, as well.)
We've had a few questions lately from customers seeing flicker with tungsten sources especially at higher frame rates where you can't sync the shutter to 50/60Hz.
Tungsten sources can flicker because they aren't truly continuous sources.
Most tungsten sources don't appear to flicker because their decay from on to off is slow enough that it's not visible. With some sources (usually regular incandescent) the filament will decay faster and cause flicker (smaller filament and faster cooling).
HMI's with electronic ballasts, continuous (not pulsed) LEDs sources, or DC powered tungsten are the best ways to make sure you don't get flicker.
This side benefit is that HMI and LED sources balanced to daylight will provide a much nicer blue channel whereas with tungsten, you're under exposing blue significanly.
Deanan
But, for a rolling shutter digital camera 1/120 seconds exposure time at 24 fps will be "flicker free" and 3/240 seconds exposure time at 24 fps will be bad flicker.
Hi Deanan,
What do I do if I'm shooting in an airport with several thousand
magnetic ballast warm white delux (3200K) tubes banging away
up in the ceiling on a ten hour night shoot?
Can't turn them off cause they are all in shot, can't change them to daylight
for budget/political reasons. Any Ideas?
Mezmo
How would you calculate the same rates for film with a shutter that is wiping across the frame from left to right or top to bottom?
We did some tests last night, under street light, and strobed like crazy, even at 24fps. We're shooting several street scenes here in a couple of weeks, so we'll need to black out all the street lights and light from scratch. (I always planned to light from scratch, but didn't realise we'd have to black out like this.) No idea what kind of light-source is in an Australian street lamp, but this is probably going to be an ongoing issue for us.
They'll be iron ballasted mercury or sodium vapor lamps most likely. They flicker like crazy at 100Hz. Iron ballasted fluros aren't quite as bad as the phosphor has some afterglow so it doesn't stop completely emitting light when the current crosses zero.
Thanks for that.......MezmoThe initial note was referring specifically to higher frame rates, smaller shutter angles, and some tungsten lights whose filaments cool fast enough to cause some flicker. Shooting at 1/60th or 144degrees (or 72deg) would work fine. We're by no means saying that shooting tungsten is not possible, only that some light can cause flicker even though most don't. Likewise, shooting tungsten color temp lights is not bad, just that daylight is more optimal if you intend to white balance back to daylight.
