Erase a clip in RC on a mac?
Emmanuel Cambier
56
South West France
www.ecmp-prod.com
Dumbest question, but I can't find a way to erase a clip from a project.
Also is there a way to export only a chosen clip from a project containing several clips.
Emmanuel
http://www.reduser.net/forum/showthread.php?p=164487#post164487
q
Can we delete multiple clips at one time yet? I haven't loaded or tested the new version yet
a
You've always been able to do this.
In the Library, Ctrl/Option-select clips and Trash them.
a2
That doesn't work on my redcine. Maybe on scratch. I control select and when I hit trash nothing happens. That's what I get.
a3
shift selct works for me - if that´s what you mean
Emmanuel
Answer, Yes and Yes.
To erase clips;
- Shift Select all the clips you would like to delete.
- In the Right corner in the Library select, Trash Selected,
- you will then be prompted, Confirm deleting selected nodes, hit Okay. DONE
To Export 1 Single clip out of a larger project,
- Go into the Player, click on the clip you want to Export,
- Hit "RANGE" , This will select only that clip in the timebar for playback,
- go to output, select your settings and export,
- REDCINE will only export the Ranged Clip.
Enjoy!!!
