Eli Jarra
- Dec 30, 2006
- Los Angeles
- www.thinkpictures.com
I love the imbedded timelapse/intervolometer feature in my Red. I've only shot a handful of TL since getting the cameras. I find the feature very flexible and easy to use and for the most part reliable...Now I'm starting to notice a pattern of missed frames that is just bummin' me out when shooting. With timelapse you get one shot at getting it right, if you miss it, or there's a technical glitch then that is a lost opportunity probably never to happen again. Once in a while you can chalk it up to Murphy but after two or three times, there is definitely something wrong and needs addressing.
Over the weekend, I had the camera blasting away on a storm that came through So-Cal, after a satisfying period of time, I stopped recording and noticed the 'post' time taking longer than usual. This is the third time its happened and the last two experiences ultimately shortened the result clip by a considerable amount of frames. The first time was on set, shot for 45 seconds, retrieved only two from the r3d file. The second time was a time-lapse that was going for about two hours, again only 2 seconds returned. Same with this third time. All have the consistent extended post time followed by a "playback Error Internal Fault" message when trying to review the clip on the camera. In fact, when this error occurs, you are not able to view ANY clips on the drive through the camera. This is problematic since you must have an extra drive ready to go at a moment’s notice. Also, note camera would not boot up with said drive attached, boots only on drive being dis-connected. I’ve done some searching for the ‘playback error: internal fault but haven’t come across anything substantial. I remember reading a post by Stuart a while back asking to disable QT proxies and see if that helps. My next email is to support but I wanted to run this by the forum and see if any of you are having similar issues with the Red Raid. Oh and a time-lapse feature request please: Have the number of frames executed/recorded so far in the display to help keep track of how many frames you should expect.
Some questions... Are the frames there but just not accounted for or readable by the system? Is there anyway to retrieve them? How do I circumvent this from happening again.
Thanks for your time and insight.
System specs:
Cam 392
Beta 14, (first and second instance happened running beta 13)
Red Raid (multiple raid units)
A/C power
QT proxies OFF (third instance only)
Timelapse mode, interval 5 seconds,
Shutter 1/48
System specs:
Cam 392
A/C power
Shutter 1/48
