4K and 2K recording times
PickRED
New member
*I posted this in field tests and figured it wasn't the best place...sorry bout that* I was just wondering, if you are shooting at 4K, how much recording time does that give you on REDs 320GB drive? Also, how much recording time on the same drive shooting at 2K?
Here you are!
REDONE user manual page 52.
See you.
Pat
Compact Flash (CF) - will be available in a variety of capacities, but at this time is fixed at
8GB. Depending on resolution and frame rate, each 8GB Compact Flash card will provide over 4 minutes of 4K 24fps RAW recording, or over 12 minutes of 2K 24fps RAW.
RED-DRIVE Media - will be available in a variety of capacities, but at this time is fixed at 320GB. Depending on resolution and frame rate, each 320GB RED-DRIVE will provide approximately
180 minutes of 4K 2:1 24fp RAW recording, or 720 minutes of 2K 24fps RAW.
Thanks Tresch. That helps me out alot.
