Using external power sources (batteries)
Charles Papert
www.charlespapert.com
I've heard plenty of "there are issues with using non-RED batteries" and the like in the past year. I'd love to hear some hard facts on what the issues may be. Is it a small window of acceptable voltage, or voltage fluctuation that is causing problems? What are the ramifications of using a block battery or Steadicam batteries to power REDOne? What can be done to make it more compatible?
I apologize if this has been covered, I searched for a thread on this but couldn't find it.
HI Charles
The version 14 manual which I just cover to covered says voltage fm 11.5 to 17 which is what my other batts deliver.
Currently using Lions in 160 wh will shortly have RED gonna be bummed if all my batts won't work, but manual gives no indication like this. Never had this problem with any other camera...Where is this problem can't find on a forum search??? More concerned about the crazy airline trans. rules for Lion...
Used Hytron 140 on Red via a DSR Qucikplate. Works fine and will juice you Red about 2 hours. Also used IDX batteries (Endura Elite) and they worked also fine.
Manuel
The only thing is, the camera don't know how empty or full your battery is and shows "AC" at the battery meter.
RED batteries are smart
We tested Sony, Anton Bauer and Panasonic batteries on our camera and they all worked. Don't know about how long they will last VS the RED batteries. The problem is they don't have the smart chip the RED batteries have so the camera thinks it's on AC power. This also means if the battery runs low the camera will not do the auto shut down when it runs out of power.
The auto shut down is a really nice feature since it saves any data written prior to shut down.
I've used my Dionic 160's, Hytron 140's and my Victory block batteries and they all work fine. Obviously the Victories last longest.
You can keep an eye on the side display on the A/B's and you'll have some fair warning that you're about to die.
But it would be nice if Red could warn you of low voltage even in AC power mode, which is what it thinks you're feeding it in the absence of a Red battery. Because if your battery goes down and the camera thinks it's on AC power, it crashes, and you may have a bad file if you were rolling during the crash.
I was thinking of getting an inline voltmeter for the block batteries' cable.
This has been discussed at great length in some previous posts. It seems as though the folks at Red got the word and are going to help us somehow on this.
Harry
Hey ALL RED one current owners and future owners,
I have invested a Battery Factory in CHINA for all the Camera vendors including RED ones.
My Products :
Built-in processor on circuit board calculates the real runtime according to the load timely; calculates the remaining charge time according to the charge current timely; calculates the normal runtime according to normal power 26W of video camera.
Display the real runtime in three modes on LCD, Hours and Minutes, percent fully capacity and capacity gauge.
The InfoStore microprocessor store the vital parameters including battery’s name, chemistry characteristic, date of manufacture, charge voltage, charge current, number of cycles, cell temperature. These parameters can be displayed on the LCD of PRO-X XC-LXXD series digital chargers.
Intellicom batteries can communicate with the viewfinder of some current professional video cameras. Display the remaining runtime in gauge in the viewfinder.
The back-lighted LCD design is activated by pressing the button on the battery’s front for two seconds. Exclusive sleek design and impact case, keep LCD from outside destroying.
Intellicom batteries can be mixed with other Li-Ion batteries with the same mount on the digital chargers or normal chargers.
Founder
BWB
CHINA / Thailand
similar related question: a number of the AB chargers have a 70w plug to power the camera from mains--similar to the one in RED's charger. has anyone tried powering their camera with this plug? does it provide sufficient juice?
paul
Using 3rd party batteries is all very well and convenient if you already own them, but the possibility of your Red suddenly cutting out if you haven't monitored battery voltage is just too scary to contemplate - especially if you're using the RedDrive (hard-drives don't like suddenly losing power mid-use). The Red batteries and chargers are very reasonably priced for their impressive capacity & size. Better safe than sorry!
Again, I'm begging someone (hope fully red) to build a box (4pinxlr to camera lemo) that translates line voltage into their proprietary data stream and reports it to the camera.
People have said that their onboard to camera communication stream is more complex than that and requires specific knowledge of the cells involved (discharge curves?), if that is the case then then needs to implement a secondary lower level communication protocol that will understand simple line voltage.
I guess this could be done by firmware. I remember other cameras (was it the varicam ?) where you could chose in the menus which batteries you are using. So why couldn't the RED do it ?
For normal use I plan on using Red batteries.
But as Charles pointed out, for steadicam work it would be nice to power the camera from the steadicam (which often uses AB batteries).
This is also an important feature for people / rental houses who already own other V-Lock batteries...
Anyway, this is really important.
Let's hope this comes with build 15 or 16...
Because a RED isn't a Varicam. It's not clear yet whether Red's power circuitry is capable of that kind of monitoring or if it's even at a level that can be changed via firmware.
