Emmanuel Cambier
- Dec 28, 2006
- Age
- 56
- South West France
- www.ecmp-prod.com
AWESOME
Emmanuel
Emmanuel
I'll chime in... I'm the director of Rwanda: Hope Rises.
The Hyperdrive ended up saving our asses by allowing us not to be tethered in any way. While a laptop and external drive would've required at least a safe place to operate it (like a Landcruiser or shelter of some kind) and limited battery life, the Hyperdrive could safely spin away all day. I carried it in a shoulder sling bag along with our filters and an AC pouch (with leathermen, pens, slate, lens cleaner, etc.)
A full card took about 7-8 minutes to download - so, 1/2 realtime for 4K, faster than realtime for 2K. We would often shoot 2K for interviews for the sake of run time, and our 4K shooting tended to be shorter shots with pauses in between takes, so we never ran into problems not having a card ready to shoot.
I had to operate using a straight copy, no verification. The Hyperdrive does have a data verification mode, but it didn't seem to work with the R3D files... not sure why. The unit is designed for 10-15MB DSLR RAW files, so the size may have something to do with it. With that in mind we tried not to format the cards until necessary. I had a system of rotating cards & pockets keeping track of which cards were downloaded and ready for re-use. (If you needed to be sure, you could carry two Hyperdrive units and copy twice. Wouldn't be a bad idea anyway to have a second drive holding your shots if your environment is a little more intense)
The Hyperdrive runs on AA's, and would do 10+ cards before needing a recharge. And you can stick regular AA's in it, so the only limitation was the drive size.
I have an older Hyperdrive than what's on their site (HD80) with a 120GB hard drive (you can put any size laptop drive in it). The new model looks completely different, so YMMV.
